Purchasing an on3 turbo setup...couple questions
I couldn't find difinitive answers, so thanks for any info.
I have an ATi super damper 10% underdriven, can I still use it?
I currently have a fast 92/92 setup. Can I use that too? Is it strong enough to hold?
Also, i know it isn't ideal to keep my current cam, a tsp torquer v2 112lsa. My question is, since I would like to keep a fairly lopey idle still, would the v2 114 lsa be better or? I know about the boost cams, just seeing what options are.
And lastly, will a racetronix (walbro) 250+lph pump and svo 42 pound injectors be enough to fuel it? Thanks all. New to turbo, been doing a lot of reading, and excited!
Your damper and intake should work just fine for you.
The cam will work but isn't optimal cam timing for a turbo setup.
Your pump and injectors will most likely need upgrading if you plan on anything more 5-6lbs of boost.
Agreed^ Intake and pulley will be good. Nothing wrong with that part. As far as injectors go my guess would be that you will be running pump gas correct? Id switch to some 60lbs or 80lbs. You can usually get the 60lbs cheap off of ebay.
Might as well get a custom grind on the cam part.
Thats what I sorta figured. Now its just gonna be a summer cruiser so I don't play to run a retarted amount of boost, especially with a stock bottom end. Now not sure with the response, mostly for clarification, will the racetronix pump be enough for 60 lb injectors? If not what? Its still new in box so it would be easier to offload.
