05 S2000 (turbo LS1 swap)
Old 02-04-2014, 08:43 PM
herecomesboost's Avatar
Default 05 S2000 (turbo LS1 swap)
I've decided to go in another direction with my project car (05 Honda S2000). The previous setup was a stock F22 (11.1:1CR); 21psi with an s366; 2000cc injectors; Walbro 400lph fuel pump; Ford 8.8" rear (3.90 Richmond gears/Eaton Posi LSD; DSS 1000-hp axles). Tuned by me on E77 using AEM EMS (585rwhp). I'm running a GM flex fuel sensor, so I'm able to change fuels dynamically; although, I try to maintain at least E70.
The car was a lot of fun, but I wanted to build something different. One of my friends from the S2000 board recommended going with an LS1. I've been scouring the forums, learning as much as I can about different setups/recommendations/etc (my favorite part of a new build!) Initially, I'm going to simply swap in a stock LS1/T56 to ensure I'm able to mitigate any potential wiring gremlins/etc.
Subsequently, I plan on tossing truck manifolds on there with a decent sized turbo. My goal is 600+whp. Ideally, this build thread with be interactive. I'd love to hear feedback/recommendations/critiques from the experts on this board (and from my short time here, there seem to be quite a few).
As previously mentioned, I tune AEM (v1/v2). I saw a few threads that mentioned an AEM EMS PnP option for LS1s, but haven't been able to find any companies that actually sell the units (discontinued product?). If I'm unable to find an AEM box, I'll likely go with either HPTuners or EFI Live (input would be great!)
Progress will be glacially slow initially. My wife and I are selling our current house while we search for a new one; time to work on the car is almost non-existent. I'm going with the Import Muscle swap kit, although, I'm not sure the truck manifolds will fit with the unconventional mounts.
Pics of the flex sensor in action (E51):
Pics from a meet last fall:
Crossmember removed (need to move the EPS rack foward a few inches):
Ford 8.8"/mounting brackets:
Line locks:
Thanks for reading/looking!
Old 02-04-2014, 08:47 PM
Jeremy23's Avatar
What mount kit you gonna use?
Old 02-04-2014, 08:48 PM
Additionally, progress will be slowed by this guy *grin*
Old 02-04-2014, 08:50 PM
Import Muscle (http://www.importmuscle.com)
Old 02-04-2014, 08:55 PM
Jeremy23's Avatar
You will not be able to use truck (or any other manifolds) that face forward using a motor plate and trying to turbo, please text me at 623-210-9092, I'd like to help you (im Irishflame27 from s2ki)
Old 02-05-2014, 07:24 AM
Gerrot's Avatar
If you use the other mounts from ill speed on V8 s2000 you can use truck manifold. If not, you need short headers like a have.
Old 02-06-2014, 06:01 PM
Text sent!
I saw how you routed your manifold piping; clever. Are your mounts prototypes? They look somewhat different (same concept obviously) as the Import Muscle mounts.
I'm leaning towards HP Tuners. I'm slowly acclimating myself to the software. Obviously, tuning concepts are similar (regardless of the EMS), so the learning curve isn't too steep in my case. My wife is going shopping with friends this weekend and I'm dropping Rafa (my son) off at his grandparents house, so I'll have a little time to weld a few holes (from drilling the spot welds on the old crossmember) as well as cut the frame in a few places. I'll update with pics.
Old 02-06-2014, 10:17 PM
WstSidHomE's Avatar
hptuners or holley efi
Old 02-06-2014, 10:32 PM
DEFYANT's Avatar
Attach that Getrag V160 to the LSx!
Old 02-07-2014, 07:22 PM
Thanks!
The v160 (and the vast majority of my F series parts) sold almost immediately.
Old 02-07-2014, 09:50 PM
WstSidHomE's Avatar
Originally Posted by herecomesboost
Thanks!
the holley dominator i believe is the one where you can have a whole world of data logging different inputs etc. do some searching about the holley units and you will see what all they can do as compared to hp tuners. the one you choose just depends on what you have already and how you want to go about the rest of your setup and accessories.
Old 02-08-2014, 04:54 PM
Started cutting the frame in the requisite places (still have a small section near the brake lines/steering shaft):
One of my line locks (running two since I have ABS)/Wiring tucked; need a grommet for the firewall:
How the car is sitting currently:
Need a new hood. I'm not going to run the dumptubes in that location this time.
Old 02-14-2014, 02:55 PM
Had a few hours to work on the car today due to the snow storm.
New electrical bus/panel(s) (12v+/Ground):
Gauges wired in/working (AFR, Oil pressure, Water temp, Ethanol content analyzer, Shift light, Line locks):
Old 02-15-2014, 08:11 PM
WstSidHomE's Avatar
very clean work
Old 02-15-2014, 08:27 PM
codyseals's Avatar
This is one thread I will be following
Old 02-15-2014, 11:00 PM
Gerrot's Avatar
Text sent!
I
Homemade mounts. Same **** though.
Old 02-16-2014, 09:53 AM
very clean work
Thanks!
I hope to update regularly
Cool.
B, C, C101 plugs ready to go (flying leads currently); I'll be using the GM PCM for the engine/etc and the S2000 ECU to control ancillaries (lights/dash gauges/etc).
Old 02-16-2014, 02:10 PM
DEFYANT's Avatar
Now that I think about it, Mark Carlyle (Atomic Fusion), used an AEM V.2 ECM.
Old 03-07-2015, 02:25 PM
TPI TERROR's Avatar
Progress?
Old 03-08-2015, 12:36 PM
mistafosta's Avatar
On the ECU front, I have tuned both EFI live and HP tuners, and EFI live offers a lot more ability and fine tuning than HP does. Especially if you are familiar with building custom tune parameters and building tables (Which you likely are with AEM). If you aren't going to go Holley (Which I highly recommend if its in the budget) then I would say go EFI live all the way.
Quick Reply: 05 S2000 (turbo LS1 swap)
