torqstorm on a 4th gen 2002 ws6
Old 03-04-2014, 09:56 PM
  #61
Tranz Zam's Avatar
Cool build. I love seeing different stuff being used.
Old 03-05-2014, 02:57 AM
  #62
ericwilloughby's Avatar
I've been looking all night for an oval air inlet tube so I don't have to cut my hood or heat and smash the 4" tubing. All I can find is http://www.spectreperformance.com/mo...prod=9791which is a 5.2 x 3.1 oval to 4" adapter for ford 4.6L. Which would be the perfect size, but I haven't found the tubing yet. Junk yard?
Old 03-05-2014, 03:32 AM
  #63
Looks like the oval part just isnt long enough
http://m.ebay.com/itm/321122389729?nav=VI
Old 03-05-2014, 07:08 AM
  #64
UNDER PRESSURE MOD
The Alchemist's Avatar
Originally Posted by ericwilloughby
After tightening the belt I got 8# of boost at 5000 rpm but im way out of stock fuel pump. Damn it I hate trying to figure out fuel systems. Im to lazy to run a return line. May just use the evap line. ****
You don't HAVE to run a return line. I'm on twin in tank pumps, with one on a Hobbs switch from Lonnie's and I'm making north of 750rwhp. Granted, it's not as efficient as running a return line with a boost referenced regulator, but it still works.
I would be very careful about pushing the car too much at this point because the stock pump maxes out around 450-500rwhp naturally aspirated. With a blower it's lower because you lose power turning the blower, but still need the fuel to make the power.
If you run out of pump, it's a recipe for a torched motor. Be careful.
Old 03-05-2014, 05:55 PM
  #65
Default intake tubing
I got tired of looking for oval plastic tube so I went to the saw. THE SAW
I may change this over to solid tube one day but I need an air filter on this now.
Attached Thumbnails torqstorm on a 4th gen 2002 ws6-20140305_183317.jpg   torqstorm on a 4th gen 2002 ws6-20140305_183345.jpg   torqstorm on a 4th gen 2002 ws6-20140305_183355.jpg   torqstorm on a 4th gen 2002 ws6-20140305_183409.jpg   torqstorm on a 4th gen 2002 ws6-20140305_183440.jpg
Old 03-05-2014, 07:34 PM
  #66
JAX04's Avatar
Hey Eric, great work man! I've got your next project already in mind...
Compound boost, rear mount turbo into that supercharger
Old 03-05-2014, 08:34 PM
  #67
Oh hell no. Ive already got more power than I wanted. I'll probably try a bigger pulley, 3.1" Im gettin sideways in the first 3 gears. Im amazed the clutch is holding. Getting the tubing hooked up quitened it down a hole lot. Was kinda rattling without it. Idle spool like a cummins before. Im very very pleased with it. Iat dropped 20-30 degrees with the oem air intake hooked up. Still peaked at 60 over ambient. I'm on e85 just to be safe. I will probably try 93 oct in the next tank full.
Old 03-05-2014, 09:22 PM
  #68
SMOKNSS's Avatar
Pretty cool build. Interested in dyno numbers with this set up. It is always interesting to see people testing new products.
Old 03-06-2014, 11:48 PM
  #69
I opened this months chevy high performance and bam. Article on torq storm.
Old 03-07-2014, 05:00 AM
  #70
Blackbob's Avatar
Cool
Nice find ! Now of course everyone will buy one between the magazine and your thread,lol.
Old 03-07-2014, 05:40 AM
  #71
And the price will go up $1000
Old 03-07-2014, 06:40 AM
  #72
Blackbob's Avatar
Cool
lol, You already know !
Old 03-12-2014, 07:52 PM
  #73
Default 10# boost
I tightened the belt up and got 9#@4800 and 10#@5200. I ordered a 3.25" pulley today.
Old 03-12-2014, 08:17 PM
  #74
LT1RAY's Avatar
Going a "little" lean up top haha!
Old 03-12-2014, 09:00 PM
  #75
F'in A. Im looking into doing an external pump, reg on the schrader, and evap return
Old 03-16-2014, 11:27 PM
  #76
I did a lot today. Ordered a pod and gauges. Boost, fuel pressure, WIDE BAND. I finally broke down. I'll be seeing how far off my narrow band tuning has been these last 6 years.
And I also converted my evap line to a return line. https://ls1tech.com/forums/fueling-i...l#post18087956
Old 03-17-2014, 06:32 AM
  #77
Blackbob's Avatar
Cool
Good to hear,
Sadly you'll quickly see how erratic your tune may have been once the wideband is installed. The good news is you'll be able to more quickly and accurately dial it in.
Old 03-17-2014, 03:45 PM
  #78
Empatho's Avatar
I check in everyday for updates on your build, keep up the good work and post lots of pics and vids.
Old 03-18-2014, 07:44 PM
  #79
I changed from a 3 to 3.25" pulley. I still.have 150 kpa but at 5200 rpm now. Did some real time tuning. That feature is awesome. Gauges will be here tomorrow and ill start that install. Im curious to compare my narrow band tuning to a wide band. Unfortunately I wont be able to log wb and I doubt hpt will let me upgrade my Interface
Old 03-18-2014, 09:52 PM
  #80
offaxis's Avatar
Looks good man can't wait to see more results
Quick Reply: torqstorm on a 4th gen 2002 ws6
