need help with oil drain fitting
Old 02-15-2014, 02:56 PM
rossi89's Avatar
Default need help with oil drain fitting
Im getting ready to tap my oil pan with a -10 x 3/8" NPT Screw-In Fitting. Can anyone help me with what size bit I need. Thanks
Old 02-15-2014, 03:40 PM
Burken01's Avatar
Here ya go
Old 02-15-2014, 04:05 PM
rossi89's Avatar
Thanks man
Old 02-16-2014, 03:53 AM
eviltwin_1987's Avatar
I would step up to a 1/2 npt fitting if you can
Old 02-16-2014, 01:51 PM
rossi89's Avatar
You dont think 3/8 is big enough? Its only a drain.
Old 02-17-2014, 05:49 AM
THADD's Avatar
Get rid of it as fast and easy as you can. Not much sense in going -10 if you neck it down.
Old 02-17-2014, 10:50 AM
GMCtrk's Avatar
I use 1/2 npt tap with 45/64 drill bit
Old 02-17-2014, 11:03 AM
rossi89's Avatar
Ok thanks for the help everyone. Ill be using the 1/2 to 10an npt fitting instead.
Quick Reply: need help with oil drain fitting
