Turbo 6.0 powered mud truck, weird ticking noise with vid
Old 04-03-2014, 10:22 AM
  #41
ls1_chevelle's Avatar
*Swirl pot has pressurized radiator cap, bottom drains to non-thermostat-controlled water pump return
how would a person do this?
Old 04-03-2014, 10:47 AM
  #42
oscs's Avatar
Are your heater feed/return lines blocked off? if so, plumb it back through one of those.
Old 04-03-2014, 10:51 AM
  #43
overhere's Avatar
what transfer case are you running and what gears in it? also what axles and what gear ratio? and how tall are those tires? thanks, truck is awesome.
Old 04-03-2014, 10:59 AM
  #44
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
Just thought I’d throw out what I read. I sure didn’t do any extensive testing on it. I run the old 4 port LS1 vents because it’s what I had. Seems if 4 port was the best method the gen4 stuff and race teams would be using it.
Also the coolant system is NOT at a constant pressure at every point. Depending on the size, shape, and number of the coolant passages, pressure will raise and fall and the fluid will speed up and slow down. That’s Bernoulli's principle. 2 smaller passages branching off of a larger supply will net a higher pressure than say 4.
I can post up pictures of 2 point vents as well... what does that prove? What kind of pump is that engine using? what kind of pressure do they run in the coolant system?
I can learn....LOL...
So this caught my attention:
The proper setup all my LSx racers are using is, assuming the top of your radiator is below the steam vent port:
Many swapped vehicles, like my GTO, and probably this truck, have the radiator cap well above the front steam vent port. In that case, is a front vent even needed?
Andrew
Old 04-03-2014, 11:03 AM
  #45
oscs's Avatar
The only thing I don't understand is what he means by "open" radiator cap? Im under the impression that the radiator cap needs to be elimated or plugged if you will. Allowing all coolant to be entered into the system Via the expansion tank.
Old 04-03-2014, 11:08 AM
  #46
427
427's Avatar
The vent system is for clearing air, it does not change engine pressure if used with collection block as the return flow does not change. The air will clear from the heads with 4, if you only use the front you have the potential for air to be trapped in the rear of the cylinder heads. This causes problems in the rear cylinders in my testing, mostly showing up in cyl 7 damage.
The C6R engine uses a different coolant flow path than production engines, it is very nice!
Kurt
Old 04-03-2014, 05:02 PM
  #47
pun young's Avatar
Profab case with 2:1 in it, but might have to change that to 1.7:1 or so to help keep it off the rev limiter
2.5ton axles they have 6.72:1
Tires are 14.9 24 and they are around 50" tall
Old 04-15-2014, 09:11 AM
  #48
pun young's Avatar
finally got the motor out, time to get it cleaned up and look into new rods and pistons
Attached Thumbnails Turbo 6.0 powered mud truck, weird ticking noise with vid-photo.jpg
Old 04-17-2014, 08:05 PM
  #49
pun young's Avatar
number 7 didnt make it
Attached Thumbnails Turbo 6.0 powered mud truck, weird ticking noise with vid-hgnb.jpg   Turbo 6.0 powered mud truck, weird ticking noise with vid-hjg.jpg
Old 04-17-2014, 08:12 PM
  #50
3pedals's Avatar
better re-visit your tuneup, lol.
If I recall correctly, you only have a 2 bar map sensor, and you pegged it - thats a serious red flag, did you get a 3 bar MAP sensor yet?
Old 04-17-2014, 08:23 PM
  #51
BTLBABY's Avatar
Damn it boy! Got a little crispy...
Old 04-17-2014, 08:51 PM
  #52
oscs's Avatar
Good god that piston is FRIED!
Old 04-17-2014, 08:55 PM
  #53
3pedals's Avatar
ya that pic should be beside the word detonation, in the dictionary, haha
Old 04-20-2014, 09:32 PM
  #54
pun young's Avatar
yea the problem was, showing off and running without gauges
looked over the data, tune looked really good at around 8-10psi but when we got into the 14+psi it was just to much
redesigning the waste gate, and doing a bunch of testing before going out and trying to show off
Old 04-20-2014, 11:18 PM
  #55
sbcgenII's Avatar
Awesome truck. Please post more videos when you get it back running.
Old 04-21-2014, 06:58 AM
  #56
soccerdave's Avatar
That thing is crazy, puts all the torque right where you need it
Old 05-07-2014, 05:57 PM
  #57
pun young's Avatar
block is back from the machine shop and all the goodies in, time to get it back up and running
Attached Thumbnails Turbo 6.0 powered mud truck, weird ticking noise with vid-jh.jpg
Old 05-08-2014, 06:40 PM
  #58
BTLBABY's Avatar
Nothing better looking than a new set of forged pistons! Get to wrenching man, I'm ready to see this monster slinging in the pits!
Old 05-21-2014, 12:54 PM
  #59
pun young's Avatar
finally back in, maybe have it running this weekend
Attached Thumbnails Turbo 6.0 powered mud truck, weird ticking noise with vid-fghjk.jpg
Old 05-31-2014, 08:57 AM
  #60
pun young's Avatar
its running again, hopefully can do a little testing today, and then theres a event next weekend we are going to
Quick Reply: Turbo 6.0 powered mud truck, weird ticking noise with vid
