Turbo 6.0 powered mud truck, weird ticking noise with vid
Old 02-16-2014, 11:44 AM
pun young's Avatar
Default Turbo 6.0 powered mud truck
been doing a lot of research on here and alot of reading, finally finishing up my truck so I figured I would post it, so ill missing a lot
Specs:
6.0
custom cam
75mm turbo
holley efi
water to air intercooler
aeromotive fuel pump
th400
Took the 6.0 out of a chevy suburban
took it apart and cleaned it all up and freshen it up
back together
in the truck
all the plumbing
exhaust
gauge panel
videos of it running
Old 02-16-2014, 12:03 PM
JustAFooL's Avatar
That is bad *** man! How much boost you running on it?
Old 02-16-2014, 06:55 PM
goodwrenchbutch's Avatar
what gauges are you running?
Old 02-16-2014, 07:02 PM
coltboostin's Avatar
Looks like Pro EFI....
Old 02-16-2014, 07:29 PM
ChvyC10's Avatar
Siiiick
Old 02-16-2014, 08:29 PM
ren987's Avatar
that is awesome, I have been waiting to see what a big mud truck would do with a set up like this!
Old 02-16-2014, 08:57 PM
PontiacPOWA's Avatar
That is totally awesome. That 4wd launch was so killer
Old 02-17-2014, 08:43 PM
pun young's Avatar
thanks everyone,
we are running around 8-10 for now
should be taking it out to the first mud event this weekend, might have to change the gearing in the transfer case and get some more wheel speed
Old 02-23-2014, 02:47 PM
pun young's Avatar
ok back after the first time out with the truck, did good but seems to be building a lot of crank pressure, blew the dip stick out, the valve cover gaskets, and maybe intake gaskets
not sure if facebook video works but heres a link
https://www.facebook.com/photo.php?v...type=2&theater
Old 02-23-2014, 05:29 PM
3pedals's Avatar
Only you facebook freinds can view the vid. Try uploading it to youtube.
Old 02-23-2014, 05:34 PM
Forcefed86's Avatar
Originally Posted by pun young
thanks everyone,
Looks fun! What are the cam grind specs?
Before changing gears I'd try turning the boost up. The difference between 8 and 13lbs on my 5.3 was nutty. (same turbo). Stopped seeing massive gains around 17psi.
Old 02-23-2014, 07:33 PM
oscs's Avatar
Awesome
Old 02-23-2014, 07:41 PM
haulass350's Avatar
that is simply bad ***.....
Old 02-23-2014, 07:51 PM
Cubicylndr's Avatar
Thats epic.
Old 02-23-2014, 10:08 PM
Try making the privacy settings public, then we can view the vid on facebook
Old 02-24-2014, 07:52 AM
pun young's Avatar
Ill have to find the cam card, im not 100% sure on it was custom made after tell them what i was going to be doing.
And ill get the video up on youtube tonight, its not mine video or i would change the settings
hopefully didnt hurt the motor trying to show off
quick picture i got of it so far
Attached Thumbnails Turbo 6.0 powered mud truck, weird ticking noise with vid-me.jpg
Old 02-24-2014, 10:25 PM
BTLBABY's Avatar
Pretty wicked man!
What's your ring gap set at? Are you using the turbo with a catch can to try and pull crank case pressure?
Old 02-26-2014, 05:20 PM
pun young's Avatar
not 100% on the ring gap, and yes have a catch can, think we are going to see if i messed up anything with the motor and put bigger breathers on the valve covers
my motor guy think the intake temperature got to hot and might of hurt something
finally got the video uploaded
Old 02-26-2014, 06:16 PM
BTLBABY's Avatar
Yeah, looks like at the end of the video you might have hurt something. Looks like it's a hot rod though!
I'm surprised to see you say that about the IATs. Aren't you running an A/W inner cooler? Is it to small or did you run out of ice and water?
Old 02-26-2014, 07:14 PM
pun young's Avatar
the intercooler was almost to hot to touch, we ran out of ice in the cooler, going to pull the datalog when i get it cleaned up and back to the shop and see what everything was. hopefully its something simple and we dont have to pull the motor back out
Quick Reply: Turbo 6.0 powered mud truck, weird ticking noise with vid
