P-1SC tentioner pulley not lining up
Old 02-16-2014, 02:36 PM
96TransAmboosted's Avatar
Default P-1SC tentioner pulley not lining up
I bought this from a member, the bracket is for A lt1 camaro AB011-4. The tentioner has no numbers on it at all. The crank pulley has DC009A-8 its 8 inch 8 rib. When the bracket is instslled on the charger the tentioner sits to high for the belt to work correctly. I have a manuel that Bob sent me and that was helpful but did not address this. Maybe i have the wrong tentioner or pulley just not sure what i need. The bracket fits the car perfect, the crank pulley fits the tentioner not.
Pictures attached
Attached Thumbnails P-1SC tentioner pulley not lining up-cam00010.jpg   P-1SC tentioner pulley not lining up-cam00012.jpg   P-1SC tentioner pulley not lining up-cam00008.jpg   P-1SC tentioner pulley not lining up-cam00017.jpg   P-1SC tentioner pulley not lining up-cam00011.jpg
Old 02-17-2014, 07:29 AM
Im starting to think i have a LS1 pulley on the blower instead of a lt1 pulley. Can someone please post a picture of there lt1 blower pulley for a procharger so i can compair the 2. Bob said lt1 use a offset pulley and i want to see one before i go ordering anything. Thanks Tom
Old 02-17-2014, 08:34 AM
spilner's Avatar
i have a disc on my lt1 and it does use the offset pulley. i have a extra at home that i can look at later
Old 02-17-2014, 09:06 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
I know on the ls1 setups, you need the two spacers behind the head unit pulley to get it to line up properly.
Attached Thumbnails P-1SC tentioner pulley not lining up-2011-06-16_19-30-11_242.jpg
Old 02-17-2014, 05:29 PM
This looks like my issue, my pulley is flat and yours stick outward. Someone must have swapped the pulley to a ls style. Thank you for taking the time to post this picture it helped a lot
Old 03-19-2014, 11:34 PM
96famaro's Avatar
Location: Weatherford Tx 76085 corner of N. Hwy 51 and 150 Green branch Rd.
Not sure if you have it all figured out, but the blower pulley is definitely not the right one. Lt1 uses an offset pulley.
Quick Reply: P-1SC tentioner pulley not lining up
