383ci stroked twin turbo'ed ls1'
Me and my brother are building his ls1 out of his 01 camaro we are at 400rwhp ( mostly stock with headers,cold air, and blueprinted) with the t56 but im wondering if anybody has done this and how much hp (your best guess) running 15lbs boost
Details:
Forged crank
forged h beam rods
flat top pistons
lsx fast intake
probably aftermarket heads
twin 76-90 mm turbos
built stage 3 t56 viper kit
4.10 rear gear in a ford 9"
Street tires/ barely Dot tread
Turbo headers
nasty turbo compatible cam
upgraded fuel rails
msd ignition
Forged crank
forged h beam rods
flat top pistons
lsx fast intake
Turbo headers
upgraded fuel rails
msd ignition
Use a 4.8/5.3L Iron Block, not the LS1/6 Block. Get some dished pistons, flat top may be too much CR depending on the heads. Ditch the FAST intake and use an LS6. Definitely get with aftermarket heads, TFS, AFR, PRC, Mast etc. Turbos a WAYYYYY too big, Outlaw Drag Radial Guys use either 76mm or 88mm Turbos and the go 6's. I would do a 4L80e for a street car as opposed to a T56. Also, 4.10s will be too much gear. No need for Turbo headers either, truck manifolds will work fine. Fuel Rails are a definite, you will also a higher LPH rater pump(s) and an adjustable FRP. No need for an MSD ignition, use stock coils.
