Twin turbo sizes
I'm looking to make at the least 500rwhp but would like around 650-700rwhp. It's gonna be a daily driver. I plan on putting a cam, heads, head studs, rod pins, intake, inter cooler, 80#injectors, twin fuel pumps, and water/meth injection. It'll be going in a early 2000's s10. A better manual transmission. Most likely with a 4l60e tranny and a 12 bolt rear. Possibly going to spray it also but not until it's together and running good.
A pair of T3/T4 hybrid turbos will do the trick and not break a sweat doing it.
A stage 3 turbine wheel with a .63 A/R and a 57 trim compressor wheel will easily
make 800 HP and spool lightning fast on your 5.3.
If you mod your motor with cam and heads and you want to turn 6k+ RPM
You can run a stage 5 turbine and a .82A/R on the exhaust side of the turbo.
Or you can run a pair of GT35's and they are good for 900+ HP
Hope this helps you get started.
AGP offer this sort of thing for their lower kits and might just get you there with very fast spool
http://www.agpturbo.com/borg-warner-...-turbocharger/
Or slightly bigger
And discussion here with some dyno graphs etc
http://www.camaro5.com/forums/showthread.php?t=288657
Or slightly bigger
Thank you guys. Still looking and exploring my options to make sure I make the best decision so any other input you have before I put it all together I'd be more than happy to hear it. And that's goes for everything not just the turbo setup
