Why can't I find Turbonetics 7675/7875 dyno results
I have been searching for dyno results of the new turbonetics 7675 or 7875. I was able to find one or two at low boost. Surely there has to be some real numbers out there showing what these turbos can make. Or even back to back results comparing the pt7675, tc78, etc. Anyone?
I am putting my car together and have the billet turbonetics 76/75 going on and just want to see some real numbers with it. Maybe ill be the first to post some dyno graphs in a few months.
No dyno, but my friend used a 7675 (7575 or whatever they call them now) went 9.875@150 in his t56 FC rx7 (3000lbs now or so) and a god awful 1.69 60 ft. It's a forged ~9.5:1 6.0l iron block with 317 heads I ported and a 224 single pattern cam. It's a little much engine for that turbo, but that makes it respond nice and it fits in the car well. That was at 18-20psi non intercooled using e85 for fuel and dual 50/50 meth system. I'm not sure how much it has left in it, but that run was the one and only time he went to the track last year.
You might have come across my results with the 7875, but here is a dyno graph of one of the runs. This was on 15-16 lbs.
I swapped to the 7875 from an ON3 76mm and the ON3 dyno on 14 lbs. is below.
I went 9.92 @ 140 with the 7875 on 14 lbs.
Would have went faster but blew the charge pipe off on 18 lbs.
I put a pair of 7875's on my fox, ran 7668's(tc76's) last year, I'll have some track numbers for comparision this year. Still would love to see a back to back dyno with the tc76, 7875, and precision billet 7675, we was going to do that for Huron speed, but some things came up and was unable to do so.
