Have you guys seen this Cast turbo manifold?
Old 02-21-2014, 10:42 PM
LT1PWRD's Avatar
Default Have you guys seen this Cast turbo manifold?
May be old news to some,but i figured id put it up. It's geared towards the truck installs cuz of the height, don't think it'll wont work on a car. Nice piece but waaay overpriced for most i think. I'm sure it took alot of engineering and it's made outta cast stainless. There's more pics and info if you google it.
http://www.racepartsolutions.com/ind...part-solutions
Old 02-21-2014, 11:34 PM
schriefer's Avatar
Default truck kit
It is a cast manifold from trick performance for use on a truck kit. It uses the existing driver side manifold and the crossover connects behind the engine if I recall correctly.
Old 02-21-2014, 11:41 PM
dmaxvaz's Avatar
its not priced that bad. if you buy all the parts in sch 10 stainless, mock everything up and weld it up, you will have a great deal of time and money into it. so 600 bucks is a pretty good deal
Old 02-22-2014, 10:00 AM
schriefer's Avatar
Default here's a link
http://www.shop.trickperformanceproducts.com/Stage-3-GM-turbo-kit-Stage-3-GM-Turbo-kit.htm
^ here's a link to one of the kits it is used on.
Old 02-22-2014, 11:59 AM
Truck Sponsor
TrickPerformanceProducts's Avatar
It is designed to work on trucks.
But could fit swapped over LS into other platforms.
one could cut the inlet and/or outlet off and modify to fit.
As long as the main manifold clears frames etc.
Old 02-22-2014, 08:01 PM
Hi Volume's Avatar
that manifold makes me want to buy a truck now!!! hahaha
Quick Reply: Have you guys seen this Cast turbo manifold?
