88 Mustang 5.3/S475/4L80E Swap First Track Outing
Old 03-02-2014, 08:20 PM
TDMKR496's Avatar
Default 88 Mustang 5.3/S475/4L80E Swap First Track Outing
Took my 88 Mustang 5.3/S475/4L80E swap to the track today for the first time. Set it to make about 8 lbs of boost, AFR's were 11.4-6 and timing was about 15 degrees, very conservative I know but I wanted to be safe. Car went 6.98 @ 99 MPH and 1.62 60' Car has alot more left in it but I had a blast and didn't break anything!
Old 03-03-2014, 02:51 PM
5.3parts's Avatar
Awesome!!
Old 03-03-2014, 05:33 PM
jleews6's Avatar
Your car runs good. Whats done to the motor ?
Old 03-13-2014, 08:37 AM
TDMKR496's Avatar
Thanks guys! Motor is a stock 04 5.3 with LS6 valve springs
Old 03-13-2014, 08:53 AM
Camaro9969's Avatar
Nice work man so much left in there!! Keep it up. What cam do you have?
Old 03-13-2014, 09:50 AM
TDMKR496's Avatar
Thanks! Stock 5.3 cam for now, but I have an 03 Z06 cam. I'll pull the motor this summer and swap the cam, springs, and head studs. I'm thinking about doing a little head work at the same time but I don't know if its really worth the power gain. They are just 852's
Old 04-26-2014, 11:47 PM
TDMKR496's Avatar
Went to the local 1/4 mile track last night. Car went 10.51 @134 1.58 60' on 14 lbs and 10 degrees of timing. I'm having some issues with the converter locking and unlocking during the 3rd gear shift, but other than that I'm very happy with the car!
Old 06-12-2014, 03:13 PM
TDMKR496's Avatar
Had a buddy throw the car on the dyno last week, made 568 on low timing and 14 lbs of boost, stock 5.3 w/ls6 valve springs and 80lb injectors, love this thing!
Old 06-12-2014, 03:37 PM
RonSSNova's Avatar
Nice!
I bet 14 lbs is a lot more fun than 8 huh!
Wait till you put cam etc in it.
Ron
Old 06-12-2014, 09:47 PM
mr.nova's Avatar
What's the specs on the s475 thanks
Old 06-13-2014, 06:27 AM
forcd ind's Avatar
pretty cool
Old 06-13-2014, 07:06 AM
TDMKR496's Avatar
Thanks guys, turbo is a 75mm, 87mm turbine 1.10 housing, lights pretty quick. 14 lbs is useless on the street with radials but is a total blast. Still chipping away at the tune, but I love driving this thing!
Old 06-13-2014, 11:40 AM
MUSTANGBRKR02's Avatar
Congrats so far not bad at all for a stock 5.3. See what it will do with some more boost before doing anything else.
Old 06-13-2014, 11:43 AM
TDMKR496's Avatar
I have heard 15 psi is it for the stock TTY head bolts, not sure if I want to push the issue.
Old 06-13-2014, 12:06 PM
Sarg's Avatar
Congrats. Can't wait to get mine all sorted so I can get it back out to the track.
Old 06-13-2014, 11:11 PM
Blackpanther99's Avatar
Moves great.
Old 06-14-2014, 08:49 AM
TDMKR496's Avatar
Thanks guys, its well worth the wait. I'm working on a rear disk brake swap on it now.
Old 06-14-2014, 10:13 AM
Restricted User
JoeNova's Avatar
Grab some head studs from Asper for less than $100. You can put them in without removing the heads, just install them one at a time using the normal torque sequence for installing bolts/studs.
Lots of people use PSI ratings for EVERYTHING. PSI is irrelevant to almost every piece of hardware other than your fuel pressure regulator and map since. Torque/HP often dictate how long parts will last.
Old 06-14-2014, 01:48 PM
topbrent's Avatar
Nice runs! Looks like a fun car.
What does the Mustang weigh with you in it?
Old 06-18-2014, 03:36 PM
5.3parts's Avatar
568 HP / 545 TQ - YouTube
How much timing?
Quick Reply: 88 Mustang 5.3/S475/4L80E Swap First Track Outing
