View Poll Results: Turbo motor choices.
Run LS1 as is.
5
35.71%
317 heads and ARP head bolts on LS1 and turbo it.
4
28.57%
Buy a 5.3, swap all the parts, sell LS1 as a long block.
5
35.71%
Voters: 14. You may not vote on this poll
Turbo motor advice
Old 03-06-2014, 01:59 PM
sherm6998's Avatar
Default Turbo motor advice
Need some help deciding what motor to run. I have a 1998 Z28 A4 with 87,000 miles. The motor has ARP rod bolts, a 220/220 .581/.581 cam, Comp 918 springs and hardened pushrods. I just purchased a 3000-3200 Circle D converter and Im going to buy the CX Racing turbo kit.
Im a little nervous about scattering the LS1 with a turbo. I have 3 options I'm considering.
1. Run my ls1 as is and keep the boost low.
2. Buy some 317 heads, head gaskets and Head bolts and run the LS1.
3. Buy a 5.3, swap the cam, rod bolts, pushrods, springs, coolant temp sensor and oil pan and run the crap out of it. Sell my LS1 as a long block.
Id like some advice from people that have done a similar swap or went the same direction with their LS1.
Thanks
Old 03-06-2014, 03:44 PM
LS1NOVA's Avatar
Low boost sucks. Build a 5.3 and turn it up!
Old 03-06-2014, 08:33 PM
mrstepheneades's Avatar
Stud the ls1 lol. Thats my only issue with mine is pushing a little water. And I'm on 21 psi lol. Good tune is a must.
Old 03-06-2014, 09:13 PM
LT1RAY's Avatar
I have a stock ls1 with 317 heads, ls9 gaskets, and pro comp head studs. I would have used the 853 heads but they had the notch in them so I couldn't run a mls type head gasket. 127k and on 14lbs now. Option 2 or 3 are both good choices, with option 3 you might even make a little money.
Old 03-07-2014, 06:36 AM
Ryans99ls1's Avatar
put 317s, ls9 gaskets and studs in the ls1. 05 and older 5.3 are the exact same as the ls1 in terms of rotating assembly (smaller bore obviously). 05+ has better rods.
With a good tune, the rods are the weak point, not the cylinder wall thickness. I have had no issues between 9-16psi. Throw some E85 in and crank it up.
Old 03-07-2014, 08:47 AM
Forgot to mention im all stock 130000 mile ls1 except cam upgrade.
Old 03-08-2014, 11:52 AM
sherm6998's Avatar
Thanks for the input guys. I have decided to buy a 5.3 and swap the parts. I am going to sell the LS1 instead of taking a chance of blowing it up. Might as well get a little more money for the project.
Old 03-08-2014, 12:17 PM
99tramsamc/fia's Avatar
Thats what i'd do.
Old 03-08-2014, 07:57 PM
MonmouthCtyLS7's Avatar
Good decision.
Quick Reply: Turbo motor advice
