Gt45 for my build or not???? Need to know asap
IM ORDERING A TURBO NOW AND NEED TO KNOW IF THIS IS TO SMALL OR JUST RIGHT!!! I WOULD LIKE TO GO BIGGER BUT IM NOT SURE
I HAVE A BONE STOCK 5.3 WITH 799 HEADS AND A TU1 CAM, LS6 INTAKE, .650 SPRINGS, 80# INJECTORS AND PLANS TO RUN E-85 ON A HURON SPEED KIT WITH T4 FLANGE
TH400 WITH RMVB AND TURBO SPECD STALL 3600+
3.23 GEARED REAREND ON 26" TIRES
TURBO IM LOOKING AT IS A GT45
Cold Side:
Compressor Wheel 69mm
.66 a/r
5” Inlet and 3” Compressor Outlet
Inducer- 69mm
Exducer- 98mm
Exhaust Side:
Exhaust Housing T-4 Flange
Exhaust Housing Outlet- 4" v-band
1.05 ar Exhaust Housing
4" V-band Outlet
Inducer- 88.1mm
Exducer- 77mm
IS THIS TOO SMALL, JUST RIGHT?
I WANT AS MUCH POWER AS POSSIBLE AND OVER 18PSI
ANYONE ELSE HAVE MY COMBO SETUP AND IS THIS POSSIBLE AND A SOLID BUILD ?
THANKS
Cold Side:
.66 a/r
Inducer- 69mm
Exducer- 98mm
Exhaust Side:
4" V-band Outlet
Inducer- 88.1mm
Exducer- 77mm
THANKS
the gt45 is a small/mid frame turbo and china made. my suggestion would be a 78/75 Turbonetics from Huron Speed. better turbo with a good warranty. Or get a B/w
