F1-A Iron 370 Cooling Question
On my old setup (Heads/cam ls1) I ran a FAST 102 with coolant blockoffs on the rear of the head. Would I be able to run the block offs safely with a Iron block and boost or should I explore other options to setup the crossover in the rear with a FAST 102?
8 Second Truck Club
I'd probably stick with with the steam ports. Even if they don't help your cooling issue, they do benefit by keeping hot spots out of the heads. Run straight water or with water wetter. Water cools better than antifreeze.
In the small event it is gonna freeze in el paso, just drain it and leave the cap off over night. However, it'll be awhile before you have to worry about that again. Its warming up!
