Lingenfelter intercooled intake for a turbo application?
Old 03-16-2014, 12:50 PM
FAST LS1's Avatar
Default Lingenfelter intercooled intake for a turbo application?
I know it's not cheap, but would this be a better option in terms of packaging and performance for a turbo application in a swap? I'm guessing you'd have about $4k in this water cooled setup, but it eliminates all the piping to the intercooler, the air to air intercooler, and all the space it takes up.
http://www.lingenfelter.com/mm5/merc...5#.UyXjE_mwJcQ
In some of the other literature it's rated for 1600hp which is beyond my goal of about 1000. I haven't bought a manifold yet either so I would be spending $500 on some kind of intake anyway.
Old 03-16-2014, 01:15 PM
Project GatTagO's Avatar
Received 1,388 Likes on 877 Posts
Here is another option along those lines...
http://www.yellowbullet.com/forum/sh...d.php?t=549765
Andrew
Old 03-16-2014, 09:20 PM
BLINGOLE's Avatar
all those are nasty intakes
Old 03-16-2014, 09:31 PM
345LSX's Avatar
+1 and the price seems to be within reason too..
Old 03-16-2014, 09:35 PM
krwyellowZ28's Avatar
For a turbo application I would look at the Nelson intercooled X-Ram.
Old 03-17-2014, 08:47 AM
6togo's Avatar
This might be a nice option for my twin build i would like to see some #'s from testing though! Any other mani builder making one that is shorter than the holley?
Old 03-17-2014, 12:40 PM
novaflash2002's Avatar
417 motorsports makes a drop in for the holley intake.... $1295 plus what ever the intake costs ya.
Old 03-17-2014, 12:45 PM
6togo's Avatar
Yes but it add's 2.5" to the already to tall holley intake it would be over 14"s!
Old 03-17-2014, 12:56 PM
you can get a mid rise
Old 03-17-2014, 06:28 PM
FAST LS1's Avatar
Yep, from reading the yellowbullet thread, if you get the mid-rise and their intercooler, it's only about as tall as the high rise Holley, 12.xx"
The Lingenfelter is only 9.13" tall, which is about what a standard truck intake is I believe.
Old 03-17-2014, 11:34 PM
6togo's Avatar
I hear the mid rise dont flow well at all VS the hi ram!
Old 03-18-2014, 03:38 AM
chuntington101's Avatar
looking at the Nelson intercoooled X-Ram is there sufficient space after the changecooler bricks to allow for even air distribution across the cylinders? To me it looks very tight and almost like each cylinder will only be using a small part of the chargecooler.
Old 03-18-2014, 06:50 PM
FAST LS1's Avatar
It clearly makes less peak hp than the hi ram.
http://www.superchevy.com/technical/.../photo_16.html
It was only off 20hp at the peak, which would probably be negligible in a FI application unless you're turning a lot of rpm.
http://www.superchevy.com/technical/...o_new_heights/
Old 03-18-2014, 07:06 PM
stevieturbo's Avatar
Is a simple A2A not an option ?
It just baffles me why they go to the lengths of developing a charge air cooler....then go about bolting it directly to a 200degF engine...all made from highly conductive aluminum.
So not only has it to deal with charge air temperatures, but the hot engine temperature too.
At least an A2A or remote mounted A2W doesnt have that huge problem from the outset
Old 03-19-2014, 09:47 AM
LS3RX7's Avatar
If there is enough interest in this "type" of intake, I may make a few of them. overall height would be about 9 inches, maybe less. 1,000+ hp A2W core, 105 tb opening, LS3,A,9 head port only. Let me know via PM.
Old 03-19-2014, 01:27 PM
345LSX's Avatar
What kind of price are you thinking about for 1 of this intakes
Old 03-19-2014, 06:05 PM
427's Avatar
That Lingenfelter looks good for the height, very cool
Kurt
Old 03-19-2014, 06:26 PM
It's the same one used on this car ?
http://www.camaro5.com/forums/showth...=283673&page=4
Old 03-19-2014, 09:47 PM
FAST LS1's Avatar
I think the benefit would be the reduced and simplified inlet plumbing. The A2A and remote A2W take up a lot of space in the front of the car in some swaps. I could plumb the discharge of the turbo right into the intake, and leave more room for routing the other pipes to and from the turbo. Plus I wouldn't have to cut out the front bumper brace to mount a huge A2A rated for 1000hp. True it's not the conventional setup, but I could see the benefit for some applications.
Old 03-19-2014, 11:43 PM
LS3RX7's Avatar
Plus i think it would save about 4-6 feet of piping,, easier packaging, less fab work and less volume for the compressor to pressurize getting into boost. Also the A2W has much less pressure loss in the charge cooler, so less compressor discharge temps. I'm building a similar intake for my TT forged LSA motor. I think if I make some of these I can get them to flow better and will be less to make and be more modular. If you want to switch cooler cores from the 3.5" thick unit and have the room, you could put a 6" thick core good for 2K+ HP.
Quick Reply: Lingenfelter intercooled intake for a turbo application?
