Wastegate Spring Question
I popped open the wastegate on my car to see what spring were run in it (I didn't build it, but I am correcting it ) It currently has 2 springs a large red and a small green. I am still learning FI so I am wanting to get some input. Currently it is running a manual boost controller set for around 8 lbs. I will be installing a truboost. If I am correct being a 44mm wastegate this means I am right around 16lbs of spring pressure. Is it better to drop to just the small green spring or use both and use the truboost to control it?
If you never need less than 8psi, then use 8psi springs.
But as there are multiple ways to configure the system, there are many rights and wrongs
Using boost pressure itself as the control signal, you cannot run a lower boost level than the base spring pressure ( mechanical losses aside, which sometimes will mean it's a little less )
So if you fitted a 16psi spring, you would never be able to run 8psi unless you sought an alternative high pressure source for the control setup.
Basically, the spring needs to be the lowest you are willing to boost and the controller allows you to go above and beyond that by relieving pressure on the waste gate?
Sorry for all the questions, just trying to make sense of what I have read so far.
If I understand you correctly, even though they told me it was only running 8psi, that is not true because it was running a 16lb spring?
What springs etc are actually fitted are relevant. As said, dont assume based on others colour charts. Make sure you refer only to your manufacturers parts and information.
If the gate was faulty or you had incredibly high backpressure pre turbine, then it may be possible to only see 8psi in the intake with 16psi springs.
It is highly unlikely though, as that would take a fairly extreme scenario.
But yes the spring needs to be the lowest boost setting you will use.
And correct the controller allows you to go higher by manipulating the opening and closing pressures applied to the valve.
