Cause for flat HP curve? Chart inside.
Old 03-26-2014, 11:47 PM
Razor's Avatar
Default Cause for flat HP curve? Chart inside.
After looking at my dyno for a couple days and comparing it to other combos, I've noticed the HP curve is relatively flat. Indication of restriction? What am I missing? (Little dip at the end was knock on this pull)
6.0 LQ Iron block 10.6 SCR
STOCK Rods, Pistons, Crank
STOCK 317 Heads w. springs, retainers
LS9 Gaskets
231/248 .617"/.595" 120+5
2.3 Whipple @13 lbs boost
102mm TB
E85
18° Timing
2" primary headers, 3" x-pipe merged into 2 1/2 magnaflows
Mustang DYNO
4l80E Trans w/ UNLOCKED converter (yank SC3000
Ford 9 Inch w/ 3.70 gear
Graph.
Old 03-27-2014, 12:00 AM
8 Second Truck Club
Blown06's Avatar
flat dyno graphs are a good thing
Old 03-27-2014, 12:34 AM
itsslow98's Avatar
Am I reading this right? Cant say ive ever seen that big of a split on a 6.0 cam before.
Old 03-27-2014, 12:40 AM
Razor's Avatar
It is correct. BTR STG 3 PD Blower Cam.
Old 03-27-2014, 05:12 AM
Exidous's Avatar
I cannot see the link but it is possible there is an inlet restriction to the blower. I know the LS9 and LSA blowers benefit quite a bit from porting the snout.
That split isn't all that unusual if you look at the LS9 cam. It just has more duration on the int and exh.
The 2.5" magnaflows may be causing it.
Old 03-27-2014, 09:29 AM
Razor's Avatar
Blower inlet is ported to accept 102 mm TB. I have a 5" intake pipe on that leading to the largest dry filter AEM makes.
Old 03-27-2014, 10:36 AM
Forcefed86's Avatar
FWIW I'd punch a baby or two for that torque "curve"...
Stock Zr1 cam is a 211/230 @121 I believe...
Old 03-27-2014, 11:21 AM
asubennett's Avatar
Pretty normal whipple graph. Its a positive thing with a whipple that you dont have a tail off in the upper rpm's. Graph looks pretty good to me. Good tuning.
Old 03-28-2014, 02:48 AM
Exidous's Avatar
122.5 but close enough. Gets the point across that big splits are pretty normal at least from the factory.
CRAZY amount of neg overlap on the ZR1 cam. 49* just seems like too much even for a stock car.
Old 03-28-2014, 03:52 AM
itsslow98's Avatar
I was talking about a 6.0 cathedral port engine. I know ls3/7/9 etc utilize a different style cam with the larger splits
Old 03-28-2014, 04:26 AM
vaethshuxun's Avatar
Old 03-28-2014, 04:28 PM
Bimmerdude's Avatar
I would expect a restriction to show up with an accelerating dropoff rate for the torque (the restriction should get exponentially worse with RPM), the rate of fall-off seems to be less than near the beginning.
What computer are you using, stock PCM?
Is the 18 degrees only near redline and reduced in the middle (could explain the shape difference I'm seeing).
A positive displacement blower should move relatively the same amount of air into the engine for each combustion event so really the shape of the curve should nearly match the shape of your engines VE curve....so if you want more top end torque/hp you would look to improve top end VE (including entire intake and exhaust system), while realizing restrictions in areas of vacuum are significantly worse than in areas of positive pressure. (back of a car has more drag than the front for the same reasons)
Old 03-28-2014, 04:37 PM
7 Second Club
NicD's Avatar
That's a normal whipple graph? Uhh no. An unlocked torque converter will not give you a real representation of the engine's powerband. In other words it wouldn't look like that if it were locked. There are so many variables that could cause one thing or another in the tune, the combo, etc that you can't really compare like that anyways.
Old 03-29-2014, 07:59 PM
Razor's Avatar
Pull was started @ 3500 RPM's.
Some have mentioned that the guy driving hammered the pedal WOT instead of rolling into it which caused the initial spike in torque.
Also, the log indicated the engine was revving to 6500 RPM vs. the 6000 RPM shown on the graph.
So far I have heard the mufflers are small, heads are holding it back, and the trans/converter might be slipping.
Old 03-29-2014, 09:43 PM
97WS6SCharged's Avatar
You sure you're not just running out of supercharger?
Old 03-30-2014, 01:39 PM
NBM-LS1's Avatar
Thats what it looks like. can you pulley it down any more?
Old 03-30-2014, 01:59 PM
Exidous's Avatar
I'd normally think running out but it shows boost held perfectly steady to redline.
Old 03-30-2014, 06:04 PM
Razor's Avatar
Its not runing out of super charger. As previously mentioned, green line represents boost...its flat/steady.
Old 03-31-2014, 10:19 AM
7 Second Club
NicD's Avatar
The spike in torque was caused by an unlocked torque converter.
He may have pulled it to 6500 rpms but the dyno stopped at 6000 rpms for potentially many reasons
The problem with a mustang dyno is that what it reads is up to the operator. It could be something as simple as operator error but I'm kind of failing to see the problem with the graph other than the dip up top which you already said was knock retard (not sure how it's pinging at 18 deg on E85 at that boost level/comp however).
Is there something in particular you have an issue with? Post up the log file showing what happened on that dyno pull because without it people are just shooting in the dark for something that may not even be a problem. What did timing start out at 3500 rpm vs redline? I'm assuming it has a ramp to it.
Quick Reply: Cause for flat HP curve? Chart inside.
