Air Filter Question
Wrong
But how small or poor was your filter in the first place ?
A 90deg bend right off the turbo is always a bad idea. Sometimes almost impossible to avoid though
Filter does look pretty small though.
Was it a single turbo, or was that one of two filters ?
It's a single. That's a 4" ID pipe and te filter is like 6.5" long. I didn't claim to have a 14" cone with 5" diameter. But a filter of any type will cause a restriction, it doesn't take an engineering degree to realize that. How much of a restriction? Not sure. I can only comment on how much I picked up.
That elbow could maybe be more of a restriction though.
If you look at the filters Camaro Andreas used on his car, they certainly werent big, but obviously two of them.
Said it made no difference removing them
Any filter would need to be posing a large restriction for it to actually make a difference to power though
Some of the filters the R35 GTR guys are using are tiny, and some of them are making 1300hp and upwards
They have two, but it's still surprising
make a pass with it on, then take it off, and see if it goes faster. That's the only way to know for sure. I know my 3900lb car picked up 1.5 MPH in the 8th.
Arranging it so it can only ever draw cool air would be worth doing. As long as that doesnt create bad pipework.
Also if space permits, always nice to have a bellmouth at the filter. Although the largest filter openings Ive seen are 6", not sure what size your turbo outlet is, and whether any bellmouth at the filter is doable.
One problem with a filter in a "hot" location. When sitting about, engine running but car not moving. The filter is always drawing in hot air. Sometimes very hot. If there is an intercooler in the system...this in turn heats the intercooler up creating a heat sink.
So it can take a short distance to get rid of that heat before any cooling can actually take place.
There is no way I'd ever run my car with no filter. One way or another there is always room for something.
It just isnt worth the risk unless you can afford to replace turbos, blowers or motors
There is always some way to add some sort of sensible filtration.
I guess the only scenario you might consider no filter, is a car that only ever see's the 1/4 mile and is never driven anywhere else. That includes down the return road back to the pits.
