Popped a Cylinder Freeze Plug on a dyno pull.....
I have a 2001 SS with a 99 4.8, APS TT, with a powerglide. The 4.8 has some worked 862 heads, LS9. eadgaskets, pro comp studs, LS6 cam, br 7 plugs.
Put it on the dyno for the final tune, first pull it knocked the damn freeze plug out of the head. 14 psi, with only 9 degrees of timing netted me 568 hp with 505 ft lbs of torque. Have any of you FI guys ever seen anything like that?
My head guy said he didnt touch the freeze plugs. I am pretty sure it didnt lift the head, and if it did wouldnt it have crushed the radiator cap? Maybe it cracked the head.....I am pulling the head off today to check it. Maybe it was just a weak freeze plug.......
pin the plug back in!! don't just blow it off if you don't find anything, make it so it can't come back out.
I have a freeze plug bore in a block that was a little over sized. it never moved during it's service as a stock 140k motor. it fell out on a burn out, I put another one in. 2 passes later I hit the wall head on at 125 when it popped out again, shortened the car up 3 feet.
The following users liked this post:
Dopeydinerdog (12-30-2022)
The more I think about it, it probably did lift the head. The boost spiked the maf, and after 15 psi we couldn't read it. Pretty sure it was my error with the boost controller. I haven't confirmed but, I have a feeling. Hell it could have seen 25+ psi for all I know. I ordered a new head gasket and it should be here later today. I am also taking the head in today to get it checked out. Then tomorrow I will strap it back on and go back to work putting her together again.
I think my manual boost controller didn't control the boost. It only has 9 lb wastegate springs in it, so I am thinking it only saw maybe 18 lbs of boost. The run was normal, the tuner did some street tuning and the we strapped her down and made the first pull, and it popped the freeze plug.
I should have the head torqued down and the turbo manifold back on today. Tomorrow all the little crap should be back on the car (intake, coils, plugs ect). I am hoping it will be ready by noon on Saturday. I did take care of the oil leak from the front main seal as well.
7 Second Club
Just saw this thread, yeah it saw nowhere near 25 psi. On the dyno we let out as soon as it came up into boost because that's when the spray started and it only registered approximately 14-15 psi and the map sensor didn't flatline indicating that it went any higher, the sensor reading was still going up at the point that I let out. Remember, this all happened within a second or two after boost hit so it made nowhere near a full pull.
