Is this normal in a catch can ?
That looks like it could be an algae growing in the catch can. I have seen it in industial oil tanks where water accumulates in the bottom of the tank (oil floats on top). The agae lives in the water layer and eats the hydrocarbons as food. That is disgusting. I need to go drain my catch can.
In a vented loop system like the factory has the water goes away once temperature is reached, it vapors off into the intake and gets wasted like humidity in the air. In a catch can system the flow goes both ways and moisture cannot be controlled. This will cause moisture to collect in the can making the mess you see.
Kurt
Kurt
