Anyone seen this happen to ATI damper?
Old 04-06-2014, 07:29 PM
zapp109's Avatar
Default Anyone seen this happen to ATI damper?
Went out today to do a few pulls after i switched my vacuum source for the wastegates. Did 3 quick pulls. Came home and popped the hood to adjust idle screw a little and noticed my belt had walked half way off my damper, and it was wobbling. Snapped 5 of the 6 bolts off the hub.... WTF!
Old 04-06-2014, 07:32 PM
transam69230's Avatar
I snapped all of the bolts off! Hub stayed on the crank and the balance slung out from under car and skidded across the road like 50ft while i was giving some girl I was trying to impress a ride, lol.
Wasn't under warranty so I ate it unfortunately.
Old 04-06-2014, 07:38 PM
zittman's Avatar
I would think you might have a balance issue....
Old 04-06-2014, 07:39 PM
zapp109's Avatar
I sure hope not its a new motor that was balanced.
Old 04-06-2014, 07:40 PM
zapp109's Avatar
Any idea what caused it?
Old 04-06-2014, 07:41 PM
Zmg00camaross's Avatar
That or improper torque on the bolts. Similar to ppl breaking wheel studs.
Old 04-06-2014, 07:50 PM
zapp109's Avatar
So i just did some research and found a good piece of info that i wish i would of known. In the instructions it says to use 9 bolts there are 3 others apparently that need to be on when not using the extra pulley that bolts on. I wish i would of known this.... i got the pulley from my engine builder and was told it was ready to put on. Well there ya have it people this is what happens when you dont do **** right.
Old 04-06-2014, 08:23 PM
JAX04's Avatar
Yep, i see alot of people with only the countersunk bolts in place. I put the three others in mine. Thats when i noticed most people dont.
Old 04-06-2014, 09:07 PM
MUSTANGBRKR02's Avatar
Sucks to see but hopefully others see this and fix theirs.
Old 04-06-2014, 09:45 PM
zapp109's Avatar
Got it off the car, any ideas on getting these bolts out? They have blue lok tite on them.
Old 04-06-2014, 09:56 PM
3pedals's Avatar
Set a flat washer over the broken bolt, then weld them together. Then weld a nut to that, and spin it out. You may be able to skip the washer, but its hard to get in deep enough with the weld.
The heat from welding will loosen the loctite. And make removal easy
Old 04-06-2014, 11:10 PM
green94z's Avatar
Over tightened, or they were loose
Old 04-06-2014, 11:29 PM
Drill and a easy out. Buy a quality but and screw extractor. Also hit it with some WD-40 and let it sit for awhile.
Old 04-06-2014, 11:33 PM
fengstang's Avatar
this.
or if it ever gets mess up just buy a new one
Old 04-07-2014, 12:29 AM
8 Second Truck Club
Blown06's Avatar
My guess is that the bolts where loose.
To the broken **** out, take it to a machine shop or weld something to it. Depending on your skill level.
Old 04-07-2014, 09:15 PM
zapp109's Avatar
Got it back together the correct way. Took a drill bit and bolt extractor and they came right out.
Old 04-07-2014, 10:24 PM
RonSSNova's Avatar
Good job.
Now go buy a lottery ticket quick!
Old 04-08-2014, 12:01 AM
Good deal.
Old 04-08-2014, 08:14 AM
Old Geezer's Avatar
Also, the taper heads are to be torqued w/ a T40+ Torx, not a std Torx.
As far as the broken bolts, I w/ those thinking they were loose, to begin with.
I just checked on a recent install. We got the extra 3 cap screws in the kit. The kit did not include the a/c belt pulley.
If the shop gave you the balancer, and not the 3 cap screws, that could have been the root cause. [AIRC, all kits come w/ those bolts.]
Old 04-08-2014, 08:23 AM
zapp109's Avatar
Well I had to go get some regular hex bolts so I don't have the torx style but in the instructions it says not putting the 3 other bolts in can cause damage and when I called ati they told me the same thing. I called ati to ask if it's okay to throw the hex bolts in and they said its fine just might have a hard time taking them back out one day.
Quick Reply: Anyone seen this happen to ATI damper?
