What's the best fuel pump and injectors to run on E85
Old 04-09-2014, 09:31 AM
ls1CANTU's Avatar
Default What's the best fuel pump and injectors to run on E85
What are y'all guys using for fuel pump, fuel lines and fuel injectors on E85? I'm looking to make 1000-1100 RWHP on a mustang that I'm building with an LS turbo setup. I will be running the Holley HP ECU.
Old 04-09-2014, 09:57 AM
schmendog's Avatar
From what I've seen most people are having good results with the Magnafuel 4303 and the Holley 1800. I plan to use the 4303 for my build.
Old 04-09-2014, 10:00 AM
Forcefed86's Avatar
The best and most expensive usually go hand in hand.
The best IMO would be injector dynamics 2000cc hi-z injectors... ($2000+) and a low mounted mechanical fuel pump that is cable driven.($1300+)
More reasonable would be 1 044 bosch inline pump ($160) on while cruising (quiet) and a magnafuel 4303 ($490) in parallel that comes on at 1lb of boost. 4303 prob won't get you there alone IMO.
Then run FIC hi-Z 120lb injectors at highish base pressures. ($1100)
-10 lines PTFE lines would be more than enough.
Old 04-09-2014, 10:16 AM
ls1CANTU's Avatar
Thanks for the reply
What low mounted mechanical fuel pump are you talking about?
Old 04-09-2014, 10:36 AM
Forcefed86's Avatar
You low mount them so you won’t have priming issues… Could also use the more common belt driven pumps and an electric pump to prime the system.
Google “Cable drive fuel pump”
These are the big names…
http://www.watermanracing.com/PagesM...%20RACING.html
http://www.cvproducts.com/Products/F...0Fuel%20Pumps/
Old 04-09-2014, 12:26 PM
willizm's Avatar
I'm running dual 340's in the stock bucket and fic2000 injectors to just shy of 1000whp on e85.
Old 04-09-2014, 01:33 PM
00duvall's Avatar
Id1300 for e85 they are made for E.
Old 04-09-2014, 03:31 PM
Ryans99ls1's Avatar
Lonnies performance claims you can get 1000+hp out of FIC 160's and dual 340s on E85. Its the setup im doing but my goals for this year are 800-900hp, next year will be over 1000
Old 04-09-2014, 05:03 PM
shawnc16's Avatar
Holley system allows you to use Low Imp injectors in which case, I would choose the Holley 160 injectors.
Old 04-09-2014, 05:42 PM
ls1CANTU's Avatar
Thanks guys. I think I'm going to go with magnafuel 4303. That's what I'm running on my camaro and works fine. I have Holley 160's and also I have a set of bosch 160's. Will try them out and see how well they do and go from there.
Old 04-09-2014, 06:40 PM
willizm's Avatar
FWIW look into the ID1300cc injectors. From what I have seen they were developed specifically for fuels like e85. Been doing alot of reading today about different injectors on the market. Seems as though the ones I have along with many of the others can be susceptible to internal corrosion although it can be hit and miss. The ID1300's have full stainless steal internals that hold up better.
Old 04-09-2014, 09:12 PM
ls1CANTU's Avatar
Thanks for the info. Will look in to them. You should swing by and check up on my car. Your are close to it. How is your car coming along?
Old 04-09-2014, 09:33 PM
willizm's Avatar
Good, it's probably side by side. Gotta call Nick tomorrow to see when I can pick it up.
Old 04-09-2014, 09:48 PM
ls1CANTU's Avatar
Cool, take some pictures. You're getting a cage built on your car your said, right?
Old 04-09-2014, 10:02 PM
willizm's Avatar
Yep, 8point. just so my wife and son don't have to worry about me when I go to the track.
Old 04-09-2014, 10:12 PM
ls1CANTU's Avatar
Cool. Send me pictures of it when done.
Old 04-10-2014, 07:14 PM
LS6 Z28's Avatar
precision 220's and definitely the holley 1800! the holley is REALLY nice and very quiet for how big the pump is.
Old 04-10-2014, 09:43 PM
Cam72aro's Avatar
Dual walbro 450's for e85, -10 feed into aeromotive rails and fic 2200cc injectors. DC at 19psi with meth is 45-50%.
Old 04-11-2014, 01:07 AM
gnx7's Avatar
2nd vote for dual Walbro 400/450lph e85 friendly pumps and -10AN line. Quiet operation vs. a buzzzzzz.
Better injectors ($$$) will idle nicer.... but more cost effective ones should perform about the same at WOT. The Holley EFI will get the job done! Total believer in that system. Running it on my '69 Chevelle alum 5.3 GTS76 project. Full 9 second street car project.
Old 04-14-2014, 07:53 PM
deeloc1's Avatar
I'm running a Magnafuel 4303 and FIC 127's with e85. Looking for 1000rwhp.
Quick Reply: What's the best fuel pump and injectors to run on E85
