What are u guys using for turbo flange bolts?
So today i was working on my car noticed some of the turbo flange bolts on the exhuast side where missing after some looking around I found a couple of them they where broken in half... Its a fresh build so still trying to iron out the problems...
The car is a twin turbo setup T4 flange with 3/8 grade 8 zinc plated bolts from Bowman... I was gona try grade 9 maybe or stainless from Catterpillar or John deere I know they have good hardware
What are u guys using?...
Stainless is good in theory, and sometimes in practise.
But as it is prone to galling up and nuts seizing onto the bolts. I'd avoid it for that reason alone.
My last build I got good quality all thread in all the common sizes like 3foot each ,with nuts, and its saved a a shitload of looking for bolts and trips to hardware store. Just chopped off exactly what I needed when I needed it. Just a tip, other suggestions save hassel of cutting/deburring but cost more.
Also your oil drains look too high, may he the angle, but the 90° fittings id def swap for something that gives a straighter shot back into the pan
I use caterpillar nuts and bolts for t3/t4 stuff. I just buy the nuts and bolts for a 6nz caterpillar turbo. they aren't stainless steel. they do work awesome though and ive never seen them break unless they were left loose. for my gt45 ebay turbos from vs racing I used the studs and nuts from a cm2250 isx cummins worked like a charm. ill see if I can get some part numbers to post when I get to work Monday.
If you are breaking bolts then you have other problems as well. Something is moving making them break. But if you wind up installing stronger bolts, use crimped lock nuts and copper thread lube on the bolts. You will be able to remove them later on without a problem. I use copper thread lube on all of my bolts for my headers, or any high heat area.
