5.3 single turbo
5.3 single turbo
im working on my 69 chevelle, already made the LS 5.3 swat and installing a custom single turbo, the engine is already attached to a TH350, but im looking to change it for a transmission whit brake, what is my bes option for it, looking to make around 800 rwhp..
Thanks ..
Thanks ..
Restricted User
A stock 4L80e with a shift kit will hold 800whp. A brake makes things a little more complicated. You'll need to re-evaluate what the transmissions main purpose is and then decide how much you want to spend.
Primary street car I would 4L80e and footbrake the car. Mostly track I would probably go TH400 since you can get the same upgrades that you would also need on the 4L80e but usually a little cheaper.
