STS scavenge pump flow rate?
I personally think its identical to the -
http://www.rbracing-rsr.com/oilsystems.htm
I use and have used multiple times, the turbowerx EXA and think its great.
Good deal.
For what its worth, I remember about 2 years ago, i helped a friend build a rear mount on his GXP and he bought the pump direct from STS and at the time, it was white, and so was the one i posted, the appeared to have the same case, and gear set case
http://www.ebay.com/itm/TurboWerx-Base-Model-Electric-Turbo-Oil-Scavenge-Pump-/110973093846?pt=Motors_Car_Truck_Parts_Accessories&hash=item19d68307d6&vxp=mtr
Assuming my STS scavenge pump is based on the same design i wonder why it says "not compatible with ATF" is ATF corrosive? I will be running either dex 3 or syncromesh
Could be because of the brass gears. I think some ATF's dont go well together with such metals ?
Really dont think you'd need anywhere near that amount of flow for a jet into the gears though
Plus that cheaper pump must be mounted vertically, which maybe isnt always practical
VDO make a neat little pump, apparently used on some BMW cars and used for cooling gearbox oil. Probably manual trans cars.
https://www.merlinmotorsport.co.uk/p...p-405040001001
Could be because of the brass gears. I think some ATF's dont go well together with such metals ? Really dont think you'd need anywhere near that amount of flow for a jet into the gears though Plus that cheaper pump must be mounted vertically, which maybe isnt always practical VDO make a neat little pump, apparently used on some BMW cars and used for cooling gearbox oil. Probably manual trans cars. https://www.merlinmotorsport.co.uk/p...p-405040001001
It isnt a case of the short time it is used. It is still always exposed to the ATF even when not in use.
I'm sure you're right though, it would probably take an incredibly long time for any harm to occur if brass is the issue. But I honestly dont know.
From what I understand, the Exa is the only pump of that nature that can be mounted in any orientation. Or almost sure I read that from Turbowerx.
None of the others have suitable oil seals between the pump section and motor section.
I cant confirm as Ive never used any others, but I'm sure I read that
Exa flows a shitload....it's probably massive overkill.
But as you say...probably the best.
Or consider their Exa Mini. Might be easier to package ? Not a huge amount smaller, but it is smaller.
http://turbowerx.com/Scavenge_Pumps/page1/page1.html
Although dont think it needs to be ultra reliable anyway. The oil jet is just an addition, not a necessity, so failure wouldnt really pose much of a problem, and really the jet would only really be doing much during a very hard launch, or under very hard acceleration g-forces where oil is forced rearwards.
These events would be quite short duration.
Exa flows a shitload....it's probably massive overkill. But as you say...probably the best. Or consider their Exa Mini. Might be easier to package ? Not a huge amount smaller, but it is smaller. http://turbowerx.com/Scavenge_Pumps/page1/page1.html Although dont think it needs to be ultra reliable anyway. The oil jet is just an addition, not a necessity, so failure wouldnt really pose much of a problem, and really the jet would only really be doing much during a very hard launch, or under very hard acceleration g-forces where oil is forced rearwards. These events would be quite short duration.
