Need AN braided lines to finish my install
what lines quick connect to the factory undercarriage lines?
I know they are 3/8 and 5/16 lines with the fuel psi regulator. I need lines that can connect to my factory undercarriage lines and to the fuel rail. THen connect to the AFPR and back to the return line..
What do I need to finish this?
Any one have a parts list for this?
PIX maybe?
Im also using a 98 corvette fuel rail with the return line built in the rail.
thx
PIX maybe?
thx
https://ls1tech.com/forums/conversio...-fittings.html
I don't care if the fitting is "updated." I wouldn't give my money to any company that can't make a decent part to begin with.
Andrew
Pure Choice makes an excellent fitting that uses a double flare on one end and goes to AN -6
http://www.purechoicemotorsports.com...rod/prd324.htm
Andrew
Andrew
Ill attest to that fitting coming off...I was driving down a back road and it blew off the fuel rail and hosed my motor but by the grace of god it did not burn my car to the ground.
I do think it was partly my fault seeing as there is two plastic clips and I think I only had one fully engaged. But, a fuel fitting should be ERROR PROOF and IDIOT PROOF.
You'll get 10 different opinions. I believe the Pure Choice solution is superior because it converts the push fitting to a SAE 45 degree double flare. You probably already own the tool to make the flare and it is suitable for high pressure use. Remember that 45 degree double flare is what's used on the brake system.
Andrew
Andrew
Andrew
Andrew
Andrew
