TWIN TURBO S366 WS6(Mrstepheneades new build, redoing everything)
Old 03-22-2015, 08:41 PM
  #341
mrstepheneades's Avatar
Originally Posted by sbdgbody
nice build what size v bands and flex pipes are u using from manifolds to turbo,s keep up the good work
2.5". I always use 2.5" vbands on manifolds. They just fit better. I used 2.5 piping cause I had it lying around lol.
Old 03-30-2015, 08:54 AM
  #342
Put the hood back on and dusted it off. Trying to stay motivated. Ordered my Bell A2A Intercooler core last week. Pics to come when I get the tanks figured out.
Old 04-02-2015, 08:25 AM
  #343
Intercooler core came in. Flows over 3000 cfm.
Now to design my tanks lol. Shouldn't have any issues with iats since I have direct air flow to it.
Old 04-11-2015, 06:56 AM
  #344
Started on my bottom tanks.
Also redoing the entire front of the car. All the weight out, tubing it all lol. Just starting the process now. Shock towers will be mostly gone. Fenders will be gone.
Old 04-11-2015, 07:58 AM
  #345
a98ws6's Avatar
Nice as always! Im jealous....i always wanted my front end cut up and braced like your doing.
Old 04-11-2015, 11:45 AM
  #346
Yeah Im in a hurry to finish but just kept looking at it and knew if I didn't do it now I'd regret not doing it. Because I've always wanted to as well
Old 04-12-2015, 08:45 PM
  #347
SKULL's Avatar
good luck. im at that stage in my build of just doing the stuff I always wanted so im not going back later to do it again
Old 04-13-2015, 07:25 AM
  #348
Bottom tanks welded on. Welded inside as well for support.
Old 04-15-2015, 08:47 AM
  #349
Diet started lol.
Im gonna put another bar going up the backside of tower and connect to the main bar for support. This is just what I got done before work.
Old 04-20-2015, 08:18 AM
  #350
More of tubing the front. Tower tubes tacked in.
Old 04-23-2015, 08:14 AM
  #351
This is starting to get fun
Old 04-23-2015, 10:06 AM
  #352
Beanslsxnova's Avatar
What a great build. Fab work on the shock towers looks Awesome. I really like how you did the small tubing on top of the apron. Are you retaining the stock fender bolt locations?
Old 04-23-2015, 10:34 AM
  #353
Yes I am. I used 3/4 .083 wall tubing and laid it in the channel that runs down the top there. I welded it in spots between the stock fender mounting holes to the existing inner fender. Also the metal is layered there so I melted in the layers in several spots because I was afraid with all the sawing they would separate. After I welded that all up I attached the two 3/4 bars to the tower bar to brace the fender. Then I cut out the excess. Leaving the stock bolt tabs in place. Goal is to cut it all out but build it before cutting that way I don't have to locate anything because im not moving it.
Old 04-23-2015, 02:16 PM
  #354
WidowMaker_13's Avatar
Your build is looking great. Cant wait to see the end product!! Keep up the good work
Old 04-23-2015, 02:21 PM
  #355
oscs's Avatar
Nice work on the inter cooler
Old 04-23-2015, 03:41 PM
  #356
Thanks guys. I plan to make a bolt on front support that houses radiator/intercooler assembly and supports bumper cover. No sure how that will turn out lol. Got to finish the intercooler and get radiator/fans finished to know how I will mount it all.
Old 04-24-2015, 04:04 AM
  #357
02sleeperz28's Avatar
Very nice work.
Old 04-27-2015, 08:28 AM
  #358
Fender diet complete. Putting stuff back in now for more mock up.
Old 04-28-2015, 07:12 AM
  #359
Put fenders back on.
Old 04-28-2015, 06:20 PM
  #360
Red89GTA's Avatar
One step closer! Can't wait to see the finished product, too bad I can't get a ride in it though, would be a blast.
Quick Reply: TWIN TURBO S366 WS6(Mrstepheneades new build, redoing everything)
