Racetronix (SMP) 160 lb/hr low impedance Injectors
Has anyone ran the Racetronix (SMP) 160 lb/hr low impedance Injectors and got them to idle good with good a/f? If so could you post your tune or let me know what you have the minimum injector pulse width, default minimum pulse width, small pulse adjust, and what do you have the injector flow rate set to? Also what fuel pressure are you running. I am trying to get these injectors to work in a 2000 camaro with an Acceleronics VersaFueler driver box. I just can't get them to idle good with good a/f ratio.
There was a thread on this comparing bosch vs. Racetronix
Racetronix posted in it with a link from their site with tuning data I believe.
Also ppl were posting they're results with them and what not.
Think the thread was actually called bosch 160 vs. Racetronix 160s...should still be in the top 4-5 pages of this section.
Edit. ..found link to thread I was following
https://ls1tech.com/forums/forced-induction/1699555-tuning-bosch-160-vs-smp-160-a.html
