Garrett GT47-88 with .96AR on 408 Opinions
Old 05-20-2014, 06:25 AM
Mgunn33's Avatar
Default Garrett GT47-88 with .96AR on 408 Opinions
Building a 408 LS with TU2 Cam and stock 317's (minus springs retainers etc) and a Edelbrock Victor intake elbow and TB. Running Holley Dominator Injection. Have a Garrett 47-88 with a .96AR.
Question is do you more experienced guys think I should swap to a larger AR or try this one first. Or can it even be done on this turbo? It is a T6. I am shooting for 1000RW HP Also I have 4:11 gears and was thinking 3:55's 275 drag radial. Thanks for any help.
Michael
Old 05-20-2014, 07:18 AM
stmz28's Avatar
That turbo works better on smaller engines you will have back pressure issues. You can get the exhaust wheel and housing upgraded
Old 05-20-2014, 07:40 AM
Mgunn33's Avatar
yea what I was kinda thinking. What does it usually run to upgrade the housing? Or is it worth just finding another turbo?
Old 05-20-2014, 07:43 AM
Blackpanther99's Avatar
Just look for another turbo.
Old 05-20-2014, 08:25 AM
smokeshow's Avatar
I would try it. If you're having issues, try a larger turbine housing. That turbo is rated to 1400hp.
Old 05-20-2014, 09:24 AM
Mgunn33's Avatar
Yea that was my other thoughts as well. I am only running 1/8 mile and should stay around 7K at the top end. Compression will be low on this motor with 9:1. Running the JE dish with 72 CC chamber 317's.
Old 05-20-2014, 11:16 AM
BMF_Racing's Avatar
You will have back pressure issues which could lead to all kinds of issues. I was in the same boat. Cheaper/easier to get a different turbo. You def want the highest gears you can run to load the turbo harder. If you do run the gt4788, at least meter the BP so you can see if its getting out of control, save it from a melt down.
Old 05-20-2014, 12:37 PM
Mgunn33's Avatar
Hey thanks. What turbo would you recommend running with the 408? Spec wise.
Old 05-20-2014, 12:44 PM
smokeshow's Avatar
Might as well go with a 100mm+. It's just impossible to make 1000hp with anything smaller.
Old 05-20-2014, 12:55 PM
7 Second Club
NicD's Avatar
From what I remember the turbine wheel is kind of the problem even with bigger a/r housings but it seems the bigger housing would be cheap to try. I would think 1000 rwhp would be doable either way but if you want to keep back pressure in check go with a bigger turbo like a GT50 to begin with. I think most turbo places would recommend the GT50 for bigger cubes as well.
Old 05-20-2014, 02:22 PM
Mgunn33's Avatar
Yea LOL Kinda like "put a bigger cam in it and go real fast" Ha.
Yea I was looking at the GT-50 also. That may be an option. Where I work we move Natural Gas in pipelines. We use compressors to boost line pressure. 15K HP coupled to a Rolls compressor. That thing goes into compressor surge at a certain load percentage, but under that it makes a lot of power and moves a lot of gas. So I am thinking if this turbo GT47-88 is kept in a sweet spot, like under so many RPMs or load, that it may work. I don't know. Maybe just go GT-50 and be done.
Thanks for the help guys. Going to pick up short block tomorrow, so wheels are turning now. Would like to drive this to track and run high 5's in the 1/8th. Thats my plan anyways.
Michael
Old 05-20-2014, 02:54 PM
smokeshow's Avatar
Michael
Lol, yeah. That turbo has enough in it to accomplish what you want. You may need to step up to the bigger turbine housing to do it. Its important to keep in mind that turbine flow is asymptotic in nature. It doesn't care what size engine its bolted to...it's going to peak at a certain mass flow regardless. A bigger engine breathes easier through a bigger turbine/housing...but so does a small engine.
Old 05-20-2014, 03:01 PM
67Firebird455's Avatar
I'd definitely move to a bigger turbine housing on a 408. It's not worth the risk to run the one you've got, I don't even want to know what the ratio would be on the hot side, hahaha.
Old 05-20-2014, 05:22 PM
trans2000am's Avatar
Let me know if u end up putting up up for sale might be interested
Old 05-20-2014, 05:28 PM
Mgunn33's Avatar
Ok great. That's good info. Who would we go through for a turbine swap?
Ok Trans2000am I sure will.
Old 05-20-2014, 06:23 PM
mike13's Avatar
Forced Induction or Turbo works can both do it.
Old 05-20-2014, 08:53 PM
Mgunn33's Avatar
Great thanks. Will compare what it costs to just finding a different turbo.
Old 05-21-2014, 02:30 AM
Mel Carlson's Avatar
Hey I sent you a message. I've got a badass turbo for that motor.
Old 05-21-2014, 06:21 AM
Mgunn33's Avatar
Badass price? LOL Thanks.
Quick Reply: Garrett GT47-88 with .96AR on 408 Opinions
