3rd vs 4th Gen Rods
Old 05-23-2014, 01:35 PM
forcd ind's Avatar
are they still "cracked" rods-crazy how they froze them and then broke them open-sup. to match the bottom/top better
Old 05-23-2014, 02:08 PM
Forcefed86's Avatar
Look for the LC9 motors. They are alum block/243 head/gen4 rods etc.. Picked my 2008 LC9 up with the harness for $500. You have to remove the DOD BS and possibly the variable valve timing. Most do away with that stuff when they buy a cam anyway. Don't discredit the 4.8's either. Noone wants them so they are usually cheap. Picked up an 06 for $600 as a spare.
I wouldn't let the absence of a 243 head effect your decision too much. From what I've seen lately you can make 700+ on the "crappy" truck 862's pretty easy. 317s are a good cheap alternative as well. I could have sold my 243's and they would have paid for my whole motor!
Old 05-23-2014, 03:15 PM
9sectruck's Avatar
Originally Posted by JoeNova
I see this from time to time. I've heard of 3 LS2 engines breaking rods below 1000 HP. At the same time I've seen 3 different engines hit 1300 HP on gen 4 rods over and over and over and repeatedly beat on them without failures. It could've been heat related or excess low-end torque that did yours in.
YA boost came in pretty damn fast.. i would agree low end tq probably bent them
Old 05-23-2014, 04:35 PM
Restricted User
JoeNova's Avatar
I need to move out of Ohio I guess. According to car-part.com, the closest LC9s are both 30 miles away and they want $3400 each.
Anyone know how much shipping is for a complete engine, lets say iron block? I'm sure somewhere out there is willing to ship.
By the way, here is yet another L33 pushing the bar. ~1250 HP on stock bottom end. Later on it eventually made 1412 HP @ 7800 RPM with stock block/rods/crank and aftermarket pistons on methanol.
https://www.youtube.com/watch?v=Awa2...ature=youtu.be
Old 05-23-2014, 04:53 PM
Forcefed86's Avatar
http://cincinnati.craigslist.org/pts/4481920950.html
Old 05-23-2014, 05:13 PM
Restricted User
JoeNova's Avatar
Haha damn. I had JUST started checking craigslist when I switched back over and seen your post. Good find.
Old 05-23-2014, 08:43 PM
Marc 85Z28's Avatar
Who needs a LC9? **** that DOD/AFM **** you have to replace, it's just extra cost. There are 3-4 L33 within a few hours drive of you for under $1000.
Old 05-24-2014, 02:08 AM
Forcefed86's Avatar
My LC9 had no AFM ****. It did require a new non DOD $28 valley cover. Thats about it. Not exactly a deal breaker if you can find one cheap.
Old 05-24-2014, 08:29 AM
Restricted User
JoeNova's Avatar
I already have an L33 for my Nova. Now I'm looking for something to pick up on the cheap to use in another build. 300 bucks is a lot cheaper than $1000.
Old 05-24-2014, 08:38 AM
Marc 85Z28's Avatar
What?
All LC9s had AFM/DOD. Your "LC9" still has the **** lifters.
Old 05-24-2014, 12:54 PM
Forcefed86's Avatar
What?
Maybe it wasn't an LC9 as I was told. Not like the badging is stamped on the block. Was an 08 alum 5.3 anyway. DOD only.
Yes It had the DOD lifters. I used the lifters from my spar 4.8. Your L33 trumps all attitude makes no sense. IMO your better off with a newer engine. If you can get one cheaper it's a no brainer.
Old 05-24-2014, 01:49 PM
  #32
CameronVic's Avatar
Nope, L33 is the only way to go fast. Read it on the innanets
Old 05-24-2014, 01:57 PM
  #33
Marc 85Z28's Avatar
Speaking of no brains... AFM=DOD
Old 05-24-2014, 01:59 PM
  #34
Restricted User
JoeNova's Avatar
It has its benefits. Aluminum block 5.3, Gen 4 pistons/rods with Gen 3 electronics. No DoD/AFM. 799/243 heads and flat top pistons. Its a good combo out of the box.
However, a fourth gen 5.3 with aluminum block is just as good once the AFM/DoD is gone.
Old 05-24-2014, 03:04 PM
  #35
Forcefed86's Avatar
Ya got me, not up to par on my 3 letter GM acronyms. That makes brainless, excellent point... I'm sure your full of them.
Old 05-25-2014, 06:26 PM
  #36
95bowtie's Avatar
I guess indiana has some good prices.
Buddy got two older 4.8s complete with harness no pcm for 500 at the pick n pull.
Got a newer iron 5.3 a few days later for 280 out the door.
Yeah you have to pull it yourself but they are a 1/4 of the cost.
Doesn't matter what year or size the motor is it's dirt cheap everyday haha.
Old 05-26-2014, 10:45 AM
  #37
forcd ind's Avatar
I pulled one of my rod/pistons out, looks like the gen 4-the rod end is bushed, wrist pin is pressed in the piston
if I can save the block's standard bore, I will reuse everything-I wanted to change the rod bolts, but the stock bolts have those sleeves in the rod cap
do new bolts not use the sleeves-the sleeve kind of stops the stock bolts from coming out
Old 01-14-2017, 02:15 PM
  #38
truckdoug's Avatar
yeah you just tug 'em out, but really, seriously just reuse the stock gen 4 bolts unless you're spinning it over 7k
I put arps in a motor what that was the cool thing to do. come to find out its a total waste of money. I should put the stock ones back in and sell the arps lol
Old 01-14-2017, 02:17 PM
  #39
truckdoug's Avatar
hey I got a good one for you guys.
I have access to a "2004 5.3" (all the info I can glean from the guy)
It has the black crank sensor and the larger 13mm valley cover bolts.
What are the chances it has a 24x reluctor and gen 4 rods?
I snagged a six liter like that but it was from an '05 truck.
Last edited by truckdoug; 01-14-2017 at 02:19 PM. Reason: lol ancient thread revivalist
Old 01-14-2017, 02:32 PM
  #40
1500HP's Avatar
Two year old thread
Quick Reply: 3rd vs 4th Gen Rods
