E85 at 800 hp..what fuel system are you guys running??
Looking to see what you guys fuel system consist of at 800ish hp level. Will dual walbros with 80lb injectors get it done??
Walbro 255's seem about maxed out at that level, there's the aem 320's for an in take option, I used the squash in tank 450's for my car they should be good to 1000 or more. I'd upgrade your feed/return lines too if you are in there. it seems like 80's are the min injector to use, I have some Bosch 1000cc I got used, but lots like around a 127#/hr injector for much more than 800ish.
80lb injectors are fine with enough pressure. Been discussed 1000 times. As well as what pumps to use and why.
For 800+ whp on 80lb injectors. Base pressure starts around 65. 3 255 walbros will do it. 3 044 bosch pumps if you want more reliability and a much better pump.
2000cc injectors are extreme overkill IMO.
I'm still a gen1 355 but I have a magnafuel mp4303 (protuner 750), holley 120lb hr injectors with 50lb base pressure. Dynod 720whp at 15lbs and was starting to spin, have it on 18lbs now and am around %90 duty cycle, going to raise the base pressure this year. E85, no meth or water injection, idles and cruises great.
