TU2 cam on stock ls1?
Restricted User
You're in the wrong section. This is the forced induction section.
BTW, pretty much any off the shelf cam has been used on a stock engine at some point. Do a search, you should find something fairly easily.
OP, Here is a member here who did the swap to a tu2.
https://ls1tech.com/forums/forced-in...c-tu2-cam.html
There is only 23 cubes between you and him. The boost is what makes the power, not the cubes at this level. If you were comparing a 346 versus a 408 ok well then that is different. There will be very little difference in power per pound of boost on both motors.
Post 12 You might be able to PM him to ask some questions.
https://ls1tech.com/forums/forced-in...u1-vs-tu2.html
