Turbo 5.3 tuning help
Old 06-15-2014, 01:15 PM
mattd428's Avatar
Default Turbo 5.3 tuning help
Tried posting in the tuning section with no help so far. I have a 2005 dbw ecu 5.3 76mm turbo 60# injectors cam 595/595 242/242 114 lsa. SD tune no o2 sensor no MAF 3bar map and t56. It hits the rev limiter (6800) then goes to REP mode. Have to turn car off let it sit for about 30 seconds then start again to get it to give it throttle again. Heres a copy of the tune any help would be great. hptuners by the way.
Old 06-15-2014, 02:36 PM
mattd428's Avatar
Few changes and a log hasnt changed anything.
File Type: hpl
Old 06-15-2014, 04:26 PM
98Camarod's Avatar
What is this DEP mode you speak of?
Are you saying you start it, it revs to the 6800 and you have to turn it off and give it throttle to run or what?
Old 06-15-2014, 05:07 PM
oscs's Avatar
I think he meant to say REP (reduced engine power)
Old 06-15-2014, 05:09 PM
mattd428's Avatar
Start it wot hits the rev limiter let and it shuts off the pedal will not actuate anymore. Shut it off for 30 seconds or so start it and the pedal works again.
Quick Reply: Turbo 5.3 tuning help
