Can I make 600rwhp with this setup?
Old 06-16-2014, 03:12 AM
Ron_Stoppable's Avatar
Default Can I make 600rwhp with this setup?
Is 550-600rwhp attainable?
-5.3 stock 706 heads
-PAC 1218s
-228r Com cam
-LS1 intake
-GT45 69mm (mounted under bed)
-3 Bar Map
-Snow methanol kit Stage 1
-4L80e (stock)
-Circle D 3200 stall 278mm version
-FORD 8.8 3.73
-Walbro 400 w/ hot wire kit
-60lb siemens deka injectors
-Aeromotive 13129 boost FPR
Old 06-16-2014, 05:24 AM
Restricted User
JoeNova's Avatar
The limiting factor is that turbo, but it should still be good to a little over 600whp.
Appears to be a fairly solid setup.
Old 06-16-2014, 09:38 AM
Forcefed86's Avatar
With enough boost I don't see why not. I wouldn't' skimp on the IC for a pump gas setup. That IC looks like it's for a honda. I'd bet your pressure drop across the core will be huge, no way it has the surface area to cool well either. Prob run better without it.
If you want to stay cheap I'd look into the 12x32x4" universal Ebay cooler. Think mine was $150. Would be better to drop the $500 on a treadstone unit or 500+ on a quality core IC.
Good luck!
Old 06-16-2014, 10:38 AM
nasty64's Avatar
Good luck, nice setup
Old 06-16-2014, 10:43 AM
Yeah only reason i went this small is because i have VERY limited space. In all honesty i would rather not run it because it would make cold side pipe routing MUCH easier. Do you think i could get away with just running meth? If i wouldve know the benefits of e85 i wouldve just did that instead. Would i need injectors larger than 80lbers for e85?
Old 06-16-2014, 12:21 PM
Restricted User
JoeNova's Avatar
80s are good to about 800whp on E85 with a fair amount of base pressure. Unfortunately your walbro won't handle that much and wasnt made for E85. With a walbro 485 it'll probably handle 600whp on E85. If you were to go E85 I would drop the intercooler especially at 600whp. One of the good things about E85 is that it burns cool enough you won't need water. You can spray straight meth.
Old 06-16-2014, 09:18 PM
Am i going to take a big hit mileage wise? What about e85 and methanol?
Old 06-16-2014, 11:13 PM
redss82's Avatar
you should be able to hit 550 plus specially if the converter can be locked at wot
Old 06-17-2014, 07:36 AM
2muchboostNY's Avatar
It is estimated that using E85 fuel you consume approximately 30-36% more fuel in comparison to Octane. You would take a bit of a hit on mpg but the performance benefits are there.
Old 06-17-2014, 07:41 AM
Blackpanther99's Avatar
600rwhp shouldnt be too hard agreeing with JoeNova
Old 06-17-2014, 04:31 PM
I think im just gonna stick with 93 and meth. Is it completely imperative that I run an intercooler? Could i just use methanol? My intercooler dimensions are 27"×7"×2.75" should i just run with the cooler and meth? I just didnt want an air restriction
Quick Reply: Can I make 600rwhp with this setup?
