Best way to do hot side/DP wrap?
Bought my DEI titanium wrap for my hot side and down pipes, I'll be using safety wire to secure it and I'm using aluminized steel.
Should I paint the tubing with anything before wrapping it?
I painted mine first with that 1200* flame proof paint you get from the auto parts store. I just let it sit in the sun for an hour or 2 then wrapped it. Put the wrap in a bucket of water first. I've done it both ways dry and wet, and trust me it's much easier to use wet. Make sure to wear some rubber gloves or something cause that stuff if full of fiberglass.
I put the pipe that I was wrapping in my vice, and that way I can maneuver around it, and keep it pulled tight as I go around. Also, be sure to where gloves. And try not to overlap the wrappings as you go, as it wastes the wrap. I was able to wrap my full crossover pipe, and my full downpipe out the fender with 25 feet I think.
You guys realize op has titanium wrap that doesn't need to be wet right? Op I have titanium wrap. I also had my pipes coated with high temp treatment previously. Just wrap them tight dry and you're good to go.
Since no one else seems to use google I will post all notes and links to the DEI TITANIUM EXHAUST WRAP.
1st note: NOTE: Design Engineering HT Silicone Coating spray is NOT recommended for DEI Titanium wrap.
http://www.designengineering.com/category/catalog/dei-cycle/motorcycle-exhaust-pipe-wrap-kits/titanium-exhaust-wrap-lr-technology
http://www.designengineering.com/files/pdfs/install/ins043-titaniumexhaustwrap.pdf
I states it right on their website. THIS IS FOR THE DEI TITANIUM EXHAUST WRAP
