On3 performance 78/76
#325
My car may 673hp and 727tq on 14lbs
Specs
Lq4 gapped rings
Tick stage 1 turbo cam
Hand ported and polished 317's
Stock ls1 intake and throttle body
Stock 6speed stock 10 bolt
60lbs injectors 340 single pump and 100%meth alky control kit single 340
DIY truck mani kit 2.5inch hotside
Car trapped 131mph leaving off of idle and granny shifting 1st to 2nd
Specs
Lq4 gapped rings
#326
[quote=olegreen94;19170711]my car may 673hp and 727tq on 14lbs
specs
lq4 gapped rings
tick stage 1 turbo cam
hand ported and polished 317's
stock ls1 intake and throttle body
stock 6speed stock 10 bolt
diy truck mani kit 2.5inch hotside
car trapped 131mph leaving off of idle and granny shifting 1st to 2nd[/
good #'s
specs
lq4 gapped rings
good #'s
#327
Iv had this turbo for about 8 months now. Ran it on 10 psi last year and made 613 rw and ran 10.3x @130. Upgraded to fic 1000s and decided to turn it up. Made 693 on 15 psi on a lean pull. Richened it up to mid 11s and made 655ish. But only ran 10.21 @131. Seems like it's about out of steam, engine is a 221 cam only lq9, 4l80e, s60 rear and weighs 3800 lbs with me in it.
#329
my car made 742rwhp at 17-18psi, 650rwhp at 15psi, and 550rhwp at 10psi, engine made 400rwhp NA
5.7 ls1, 9.0:1 compression, 243 heads,vic jr intake, torquer v2 cam, 80lb injectors,twin wally 255s, t56, 9 inch
only made about 10 passes last year on low boost(10psi), went 1.59 60', 7.1 99mph 1/8, and 11.21 124mph 1/4. never made a clean pass had suspension issues.
#330
Hello all, I'm new to the forum. I have the on3 78/75 Turbo. I have a 99 Xcab silverado. Tick ls1 stage 2 turbo came and tooley valve train 18 psi . Never dyno'd. 204k tuned by me with hp tuners. Loved the turbo. Quick spool no issues. Also running the on3 turbo kit. 4" exhaust out the rear. Engine died after 1.5 years of hard daily driving. Original timing chain broke last week. 6.0 build now
#331
After running this turbo for 2 years now, I finally made it to the track. Runs were made in 4hi on street tires, 17lbs and 14 degrees. Let out after the 1/8th.
#336
9.44 @140 is rolling.
Ive went a 6.39 @109 1/8 mile pump gas 93 with water/meth on 18lbs , on3 7875 ls1 intake manifold, 862 heads , BTR stage 2 turbo cam , Th350 , car has a race weight around 3400lbs
I'm swapping to a ls6 intake this weekend and gonna push the turbo as far as it will go on some 116 fuel in a week or so
#337
the same Camaro ran 9.56 at 140 mph this last weekend at 19 psi boost.
engine is 2005 truck engine with 706 heads,truck intake, truck manifold hot side and cast on3 78/75 . 400th leaving at 6-7psi . engine is 100% stock with a triple 12 cam btr springs, pushrods and trunion upgrade only.400th 3500 converter, 3.73 gear 3550 lbs with driver. i'll try and post a pic. I have a video but cant get it to load.
#339
Nice, gives me hope I can push it more. So far its been a good turbo but been thinking of upgrading. Damn thing just needs to get me in the 5s around 117 and I'll be happy
