What rods for boosted 5.3 and 1000 whp
Old 06-27-2014, 09:39 AM
from9rto1k's Avatar
Default What rods for boosted 5.3 and 1000 whp
What rods would u guys get semi budget
Old 06-27-2014, 11:43 AM
Restricted User
JoeNova's Avatar
Pretty much any aftermarket rod will do it. Stock 4th gen rods have done it and lasted a lot longer than expected.
Old 06-27-2014, 11:45 AM
from9rto1k's Avatar
So eagle or scat or lunati should be ok?
Old 06-27-2014, 02:28 PM
tech@Eagle's Avatar
Eagle H Beam rods with ARP 2000 bolts will suit your power needs.
Old 06-27-2014, 03:20 PM
831jd's Avatar
would those handle 28-30 lb of boost
Old 06-27-2014, 03:34 PM
tech@Eagle's Avatar
Yes, please give a call to discuss further details.
Old 06-28-2014, 06:12 AM
Restricted User
JoeNova's Avatar
Boost isn't what breaks parts. Your rods will have no idea how much boost is running through them. All they care about is HP/TQ.
Old 06-28-2014, 10:23 AM
from9rto1k's Avatar
Motor is a 04
Old 06-28-2014, 12:12 PM
yenkomike's Avatar
if your engine has gen 4 rods they are a very good rod.
if your vally cover bolts have 13 mm heads and your exaust manifold bolts have 13 mm heads it will have gen 4 rods and they are just about as strong as the rest of the engine.
Old 06-28-2014, 06:24 PM
from9rto1k's Avatar
Ill check thanks
Old 06-28-2014, 08:19 PM
LS1NOVA's Avatar
Eagle H beams in mine. Did 950w and shooting for 1200 now.
Old 06-29-2014, 12:52 AM
SilverSS's Avatar
Ive seen scat H beam finally start to let go north of 1800fwhp. I'd imagine Eagle are similar.
Old 06-29-2014, 08:10 AM
Blackpanther99's Avatar
I know a person with those rods^ Very realiable and hold up strong for a long time.
Quick Reply: What rods for boosted 5.3 and 1000 whp
