Dyno #s Round 1 - 1004ftlbs/888hp - only going 149? see pg 6
I need to check and see if I still have my man card because this thing really had me intimidated last night. Track let me make two passes without a cage. I really wanted to get a few clean ones so I rolled out(no boost) and didn't really lay into it until I was positive it was hooked up.
10.4@144 this was on about 16psi. I haven't reviewed the logs yet.
I have a build thread on here somewhere.
http://s307.photobucket.com/user/abl...?sort=3&page=1
Check out my photobucket for more pics of the build then you could ever want lol
See the video that was just posted. This thing is going to scream once I lean on it.
#34
Great work! She's got an 8 with a good 60/330 for sure.
Added you to "the list" top 5 in the country for stock block power!
https://ls1tech.com/forums/forced-in...ock-lsx-s.html
#35
Thank you!
I forgot to post but in the last few weeks I added a moly cage! I need to grab pics.
So I was sneaking up on the launch but after the 9.4 I decided to drive the car home in one piece. Vid says 40mi but to my house its closer to 70 each way.
That 1.6 was on a 4-5psi launch on the footbrake. I think I can make around 8psi on it. Next track outing I will try 8psi footbrake and maybe a few * of timing. At the track I do 5gal 93+ 5gal of C12. 9.4 was 13* and 19psi.
Anyhow end of season I will go and chase an 8 sec pass. Luckily the track owner also owns a towing company.
Check out this vid from JT76 someone please embed I am struggling lol
https://www.youtube.com/watch?v=s5oe...ature=youtu.be
#39
Thanks man.
This is my first fast auto car. Im having a hard time breaking the habit of shifting early even though I have a shift light. In the above pass I shifter at 5800 and the 9.9 pass I shifted at 5300. You glide guys think im giving up much time doing so? Id have to assume I am hurting the mph/et some.
