B15 376 LSX crate engine with a 4.5 liter Whipple!
This is a box stock B15 crate engine with a 4.5l Whipple sandrail kit. Made 1028hp with 24 pounds of boost! Then they took out the baby cam and replaced it with a bigger one which dropped the boost to 22psi and made 1079hp!
I wish I had more info like dyno sheets and cam specs but I don't at the moment. There will be an article on this test soon. But for now, here's some pics and a dyno pull.
This test is to prove that the B15 is under rated as far as strength and can safely produce a high amount of power. I believe this engine is going into a late 70's station wagon drag car. The goal was to take an easy power combo and go well into the 9's. Nothing easier than a crate engine with a bolt on blower kit on top
You'll have to keep us posted on how well the B15 holds up over time. I'm sure many others, besides myself would be interested to see how well it handles 22psi in the long run.
BTW, what was the TQ was with the larger cam at 22psi, also any idea what 15psi on the B15 (stock cam) would roughly translate into as far as HP &TQ..?
I'll post up any info I hear about. But they might not reveal too much info since this will be for a magazine article. They didn't do any pulls with that low of boost. I'd imagine 15psi would make around 850 give or take 50hp. That's just a guess though.
