D1SC and Brian Tooley Jam Cam - What will it do
Old 07-10-2014, 07:39 PM
NJC-Redss00's Avatar
Default D1SC and Brian Tooley Jam Cam - What will it do
Purchased a used d1sc off a member with front mount and aster bracket. Ordered the jam cam Brian has on his website along with his spring kit and comp trunnion upgrade.
I will be running a 4.50 pulley (recommended by bob). Fuel is 80lbs injectors and Lonnie's double with Hobbs switch.
It's going on a stock bottom end ls1 with ls6 intake kooks 1 3/4 long tubes and kooks duals (off road x pipe)
The car is an a4 with a 12 bolt
3600 stall and 3:73 gears
Any guesses on power and 1/4 et?
I am going to try and tackle this build with a friend and hope to have it completed in a couple weeks!
I'll update with results!
Old 07-10-2014, 07:48 PM
Rise of the Phoenix's Avatar
Sounds like a solid setup. 1 7/8 headers would be better, as these blower setups love to breath, but I bet you put down around 600 to 630 rwhp.
Old 07-11-2014, 09:25 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
With that size pulley, I'm guessing you'll be in the 8-10psi of boost, and would be high 500s power wise.
ET, well, that's entirely dependant on your setup.
Old 07-15-2014, 05:12 PM
MR2liter's Avatar
Add meth and turn it up... I've made 828whp on a can only 5.7 with a D1sc
Old 07-15-2014, 07:18 PM
That's damn impressive. 93 pump with meth? Any track times?
Old 07-16-2014, 07:04 PM
MR2liter's Avatar
E and meth... no track times yet..
Quick Reply: D1SC and Brian Tooley Jam Cam - What will it do
