Vac/boost manifold ideas..
Old 07-13-2014, 11:29 AM
Old Geezer's Avatar
Question Vac/boost manifold ideas..
NE1 have some neat ideas, [pics], for a manifold to mount MAP, Hobbs, etc, on/near the Vic Jr intake??
I have a FAST 4bbl t/b on the above intake, and need to get 2 MAP sensors and a Hobbs mounted in some neat fashion.
[Maps for Holley Dominator, and electric Autometer, Hobbs for 2nd pump.]
NE help is appreciated!
Old 07-13-2014, 04:41 PM
conan's Avatar
Here is my vacuum manifold, HVAC, Boost gauge, Bypass valve, Hobbs switch, and Meth injection all feed off this.
[IMG][/IMG]
Old 07-13-2014, 04:57 PM
Old Geezer's Avatar
Nice! Did you make it, or ??
1/4" feed and then smaller for the other items?
Thanks!
Old 07-13-2014, 06:38 PM
conan's Avatar
Thanks!
Ebay... http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
I'm running a ls6 intake so I used the PCV port behind the throttle body with a 3/8" hose on one side and also used the small port on the back of the intake with a 1/4" hose. I think the 3/8" alone would have been enough but I had to do something with the 2 ports so I used them both.
[IMG][/IMG]
Old 07-13-2014, 09:57 PM
Taubr Unit's Avatar
here's mine, made it from aluminum stock and cut it down on a mill, tapped it with 6 ports and the vacuum feed is on the bottom. Works like a champ
Old 07-13-2014, 10:17 PM
Man-Crush Warning
Shownomercy's Avatar
Old 07-13-2014, 11:13 PM
conan's Avatar
That's bad *** right there, very clean if you have the intake for it.
Old 07-13-2014, 11:26 PM
97WS6SCharged's Avatar
I really like this. Have any more laying around?
Old 07-14-2014, 12:11 AM
8 Second Truck Club
Blown06's Avatar
I used fuel rail stock to make mine.
Old 07-14-2014, 06:50 AM
Old Geezer's Avatar
Thanks all, for the help!
Old 07-14-2014, 09:04 AM
Ping King's Avatar
I used a pneumatic 6 port distribution manifold with push to connect fittings. Its hidden behind my intake manifold, but works great.
Quick Reply: Vac/boost manifold ideas..
