Who's running a LS next block? Few questions
Old 07-16-2014, 06:47 PM
mike13's Avatar
Default Who's running a LS next block? Few questions
Can anyone help with a few questions.
1. do they run knock sensors?
2. where did you install your oil pressure sender?
Old 07-16-2014, 08:13 PM
transam69230's Avatar
I am not runninng knock sensors. I am sure you could tap the block on the out side and run it like LS2 style.
I am turbo so we used a vacuum block with 1/8th NPT ports for my oil feeds and then tapped that block for the oil pressure sending unit. Had to extend the wires to reach.
The sender needs a positive and a ground. The block acts as a ground so if you move it off the block you will need to add a ground in order for it to read.
Old 07-16-2014, 08:21 PM
mike13's Avatar
OK, so it's not set up from Dart to install knock sensors and there's not a feed for the oil pressure sender?
Old 07-16-2014, 11:33 PM
8 Second Truck Club
Blown06's Avatar
If you need an lsnext block..........you don't need knock sensors.
Old 07-16-2014, 11:38 PM
Blackpanther99's Avatar
Youll need to tap the block, Dart didnt provide it for them.
Old 07-17-2014, 05:03 AM
MUSTANGBRKR02's Avatar
I don't need the LS Next block but I have one... I will not be running knock sensors either and have yet to think about the oil pressure sender.
Old 07-17-2014, 08:24 AM
mike13's Avatar
why wouldn't you run knock sensors? Wouldn't it be just a bit of extra information when datalogging?
Quick Reply: Who's running a LS next block? Few questions
