Fairmont 5 - 6-28-15 SOLD
Old 07-21-2014, 09:33 AM
1CAMWNDR's Avatar
4.03 bore block, pistons for 6.0 stroke and rods---but replace with 4.8 crank and rods(334"), L92 heads and single plane.
Old 07-21-2014, 01:03 PM
Moderator
denmah's Avatar
Originally Posted by Sleeperls
He might post on here but a guy in a silver coupe has made nice power with two on3 76's.
mid 5s in the 1/8 last runs i saw.
yeah he is on here,
i really like how uncomplicated one turbo is haha
its going to be a s475 or 76 gangsta or 76 billet or even thinking a cast 80... but they in my opinion do not make great power on lower boost.
Old 07-21-2014, 06:15 PM
topbrent's Avatar
Stock48's Isky 218/218 112 would be a fun, proven setup. You know it runs well into the 8's with his LQ4.
Old 07-21-2014, 06:17 PM
herecomesboost's Avatar
denmah thread? In for awesomeness!
Old 07-21-2014, 06:37 PM
nasty64's Avatar
Hell ya!!
Old 07-21-2014, 07:21 PM
Sleeperls's Avatar
Maybe just do the cheap 700.00 s475 t6.
Old 07-21-2014, 07:40 PM
vht
vht's Avatar
Another vote for the T6 475. Whatever you use, hurry up and get started!
Old 07-21-2014, 09:00 PM
Moderator
denmah's Avatar
t6 96 turbine cast s475 is #1 on my list right now hahah
and a Isky 218 or whatever jarrett spec's me
Old 07-21-2014, 09:05 PM
Sleeperls's Avatar
It would be cool to see how fast it would go with it.
Off the shelf t6 s475.
5.3 with springs and cam
th400 with a brake would be nice.
Old 07-21-2014, 09:21 PM
Forcefed86's Avatar
The S400 Apex turbos may be another option. They have a billet 11 blade S475 thats suppose to be a hot little turbo. It's an 87mm exh wheel T4 (.90 to 1.25)
Usually takes $100 less than his asking.
http://www.ebay.com/itm/Borg-Warner-...-/221498460171
I'd think with Jarrets small overlap cams something like that may spool faster and flow more up top than the cast 75. I'd guess the 96 wheel with the big T6 would be more suited towards a largish cam with more overlap and rpm.
Not that either wouldn't work great!
Old 07-21-2014, 09:33 PM
427zm's Avatar
Denmah, have you thought of squeezing it as well? Just to add some intrigue and see what it can take? A 100 on top of the twins could push low 9's. Just a thought.
Old 07-21-2014, 09:35 PM
  #32
turboventura's Avatar
I vote for the $659 cast s475 with the big turbine. Denmah a couple years ago you had a post on TTF where on a buddies mustang you guys did a different quick spool valve where it was both banks feeding half of the turbo scroll then another wastegate off of one bank into the other half of the scroll. In your opinion was it worth it or would you just do a standard divided feed?
Old 07-21-2014, 11:13 PM
  #33
007FJ's Avatar
I will be glad to see this car rolling. One thing that is great, there ought to be an easy solution for the rear end if it isn't already under there.
Old 07-22-2014, 11:34 AM
  #34
Restricted User
JoeNova's Avatar
I know you want the S475, but please try something different. You had the billet 76 in a car with a heavier trans and no cage. The results with this one would probably be similar.
Since this car is caged, I would go nuts on it. Twin On3 are about the same price as the S475 and good for a couple hundred (or more) extra horsepower.
Old 07-22-2014, 11:40 AM
  #35
Forcefed86's Avatar
True... and mounting the turbos above the hood line looks boss and makes for easy plumbing.
Old 07-22-2014, 12:02 PM
  #36
norotor7's Avatar
I would also like to see something a little different. S475's are awesome turbos for the money. That's why there's a few thousand builds using them on here.
I would like to see more twins around here. The only real extra work for twins is an extra charge pipe and down pipe. The rest is about the same work as a single. So for denmah, that's like an extra 20 minutes of work. I also want to see more On3 builds. I think they are the best quality budget turbo out right now.
So my vote is On3 61/65's for 800ish whp, or 70/65's for 1000ish whp.
Old 07-22-2014, 01:27 PM
  #37
Moderator
denmah's Avatar
it did work a little bit, but imo a good cam and smaller hotside works better than all that nonsese
Old 07-22-2014, 01:29 PM
  #38
Moderator
denmah's Avatar
i have sprayed setups on top of turbos, but with that big borg warner on there i had no problem with power production haha
yeah i always 8.8 swap them
im leaning towards 60-70-76mm on3s
yeah i want to poke em out like my truck
i just did 430 whp with a single 70mm on a 4.8 so a 6.0 with twin 70s should nail down 800+ i would hope
Old 07-22-2014, 01:57 PM
  #39
turbohf's Avatar
forged motor? or still pushing on JY motor?
Old 07-22-2014, 02:01 PM
  #40
Moderator
denmah's Avatar
it will be a junkyard motor
Quick Reply: Fairmont 5 - 6-28-15 SOLD
