Air Water IC- Water core leaking. Sealant??
I have a lot of work in my air water intercoolers. Did a leak test today before they are to be completely polished and one of them is leaking from the water core. Im not going to cut them apart and end up with a pile of scrap. I cant afford to send them out to anyone.
Has anyone successfully used a radiator or AC condenser sealant?
If so, what?
If so, How?
If so, any long term issues at all?
If so, what?
If so, How?
I then plugged one of the water ports and put an air fitting on the other. When pressurized, the gauge on the air port slowly reads pressure.
Definitely leaking inside somewhere.
