heads which are the best ?
Old 08-08-2014, 04:38 PM
LuGGNuTTls1's Avatar
Default heads which are the best ?
which stock ls heads are best for turbo set up
Old 08-08-2014, 05:37 PM
TINKRD's Avatar
ls3 best bang for the buck.
throw enough boost down any head and it'll go.
Old 08-08-2014, 10:09 PM
Blackpanther99's Avatar
Agreed^
317s aint bad at all either for the price, ppl making big power.
Old 08-08-2014, 10:11 PM
Question is what motor we talking about??
Old 08-08-2014, 10:56 PM
rotary1307cc's Avatar
LSA/ls9 are the nicest stock castings out there hands down
Old 08-08-2014, 11:13 PM
DEFYANT's Avatar
Depends on the bore. Anything under 4.065 use LSA/LS9 Heads. For a 3.905 and below, 243s are good. For 3.800 and below 799s.
Old 08-09-2014, 07:08 AM
vern6.0's Avatar
With the lsa/ls9 heads. Are the decks thick enough to handle 20+psi?
Old 08-09-2014, 11:26 AM
TINKRD's Avatar
A stock 317 can handle 23lbs. The key to keeping heads down is in the tune. Just from my experience
Old 08-09-2014, 02:35 PM
DEFYANT's Avatar
Yes, the LSA/LS9 can. It is all in the tune though.
Old 08-09-2014, 09:17 PM
redtan's Avatar
Why are 799s better than 243s on a 3.8" bore?
Old 08-10-2014, 08:09 AM
JustAFooL's Avatar
Also wondering this?.
Old 08-11-2014, 10:25 PM
NemeSS's Avatar
Me three^^^
Waiting to hear the reasoning for this.
Old 08-21-2014, 11:32 AM
thanks for the input guys looks like i need to find ls3 head
Old 08-21-2014, 12:20 PM
Photochop's Avatar
243s and 799s are the same cylinder head, some 4.8/5.3s even had mixed casting numbers on the same motor. Only 243s that came on an ls6 engine from the factory had the sodium filled valves, the rest have standard valves.
317s are essentially a 243/799 casting with larger combustion chambers on the 6.0 LQ4/LQ9 engine.
If you're boosting just go with any of these 3, best bang for the cheapest buck.
Quick Reply: heads which are the best ?
