Turbo + Nitrous + Meth Injection
Who all is doing it?
My dry kit will be in Friday and I'm anxious to see how well the 50 shot performs.
From the articles I've read it seems like no timing retard is needed for the nitrous since the methanol would prevent the possibility of knock.
Im curious if the same is true about the fuel side of the tune. My tune is richened up currently so I'm curious if most guys even change anything in the tune when spraying a dry shot on top of the meth injection.
ive done it on a few setups to help spool a turbo before i started getting better converters and anti lag setups in my cars.
it all depends on what you are doing, and how much of each item you are using.
spraying to light the turbo? spraying the whole way down the track? pump fuel?
etc etc etc
etc etc etc
Spraying before turbo or after (before IAT sensor) tuning speed density you shouldn't need to do anything. Especially with 50 shot. I've heard some running as high as 150 shot. With C16 of course. But pump, meth and 50 shot spraying before IAT should be fine. Now first time trying it out I'd recommend using 50/50 mix of pump and race to make sure. Then wing it off and watch for knock. That's what I did.
