67 Tempest 5.3 S475 First Fire Up and DRIVE (VIDEOS)
Old 08-16-2014, 07:30 PM
Chiropaul's Avatar
Default 67 Tempest 5.3 S475 First Fire Up and DRIVE (VIDEOS)
First off this forum has been an amazing, from my first build on this car with an modified LS1 to this current 5.3 I've been busting my *** on lately. I finally got everything put together this afternoon and got to fire it up for the first time today. Still a few little odds and ends to finish up. I've got a couple exhaust leaks to deal with, a small oil leak where the pressure line is at (cheap ebay plate probably). Otherwise it idled really well using a slightly tweaked HP Tuners file that I found on sloppy mechanics wiki with very similar setup.
The car is a 1967 Pontiac Tempest that I was running a modified LS1 w/ built TH400 and MS4 cam. That car was fun and fast, but I wanted boost. I've learned a TON from you guys here in this section. And got a lot of help from Lil John's as well with a custom grind cam and helping to select the right parts to go along with this.
2001 Junkyard 5.3 with S475 1.32a/r 3Bar SD Tune HPTuners, Lil John's custom grind cam, Brian Tooley Valve springs and pushrods, 80lb SD injectors, Dual 40mm JGS wastegates and 60mm JGS BOV, FTI converter, Fully built TH400, 2- derale pushers, and a bunch of other crap too
Next up is a first drive, but this was exciting enough for today!!
First Fire Up
Second Fire Up
FIRST DRIVE
Attached Thumbnails 67 Tempest 5.3 S475 First Fire Up and DRIVE (VIDEOS)-img_1157.jpg
Old 08-16-2014, 07:46 PM
rouseyss's Avatar
Beautiful!!
Old 08-16-2014, 07:54 PM
68II's Avatar
Nice job, sounds really good.
Old 08-16-2014, 08:10 PM
Chiropaul's Avatar
Thanks guys. More to come!!
Old 08-17-2014, 02:42 PM
forcd ind's Avatar
pretty cool, I like it
Old 08-17-2014, 04:00 PM
Chiropaul's Avatar
Took it for a little spin today. Running just wastegate spring pressure for now, next up is hooking up boost controller.
Video in first post
Old 08-19-2014, 11:32 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,088 Likes on 716 Posts
Very cool. I had a '64 GTO and '68 Lemans back in the day, love the 64-67 2 door body style.
Old 08-19-2014, 01:28 PM
Sarg's Avatar
Just curious about the dipstick hanging out. Other than than very cool build.
Old 08-19-2014, 03:12 PM
Chiropaul's Avatar
LOL Sarg, yes I know I have had a couple people ask the same question. I am going to be running a flexible dipstick that I should be coming from Summit today. I just stuck that stock one in there for now so no oil came out the hole, and no debris could get in.
Thanks for the compliments guys. Many many hours of work into this thing, and now many more tuning it too.
Old 08-19-2014, 03:25 PM
Chiropaul's Avatar
Thanks John, this has always been my favorite body style and I had a chance to snag this one cheap a couple years ago with a worn down 400 motor with spun bearings, bottom end knock, and a TH350 that wouldn't go into reverse. But flawless interior and good paint. Now its onto its second LS power plant. I'm sure my wife wishes I had just bought a new S4, this cost me more every month.
Old 08-19-2014, 04:42 PM
LilJohn's Avatar
Congrats on getting it fired up and going Paul!!
With that gate layin that close to the turbine housing.... might want to monitor the gate for heat stress and make sure its not getting cooked. Maybe build a little heat shield that bolts to the top two bolts of the turbine housing and comes up between the housing and the gate... simple piece of sheetmetal will work.
Old 08-19-2014, 05:46 PM
Chiropaul's Avatar
LilJohn, would a turbo blanket work?? I have one I just didn't install it for that run.
Old 08-19-2014, 06:19 PM
LilJohn's Avatar
Yea the blanket will do a good job too...thatll work fine.
Quick Reply: 67 Tempest 5.3 S475 First Fire Up and DRIVE (VIDEOS)
