Procharger iron block p/s bracket help
Does anyone here have any pics of exactly how the iron block Procharger p/s bracket mounts? I've drilled and tapped the extra hole but can't figure out how the brace attaches! I'm wondering if I'm missing a extra part. I called Procharger but they offer only the pics for the alum. Block mount and are no help. Or does anyone know a specific person at Procharger that I could ask to Speak with that would know about this. Thanks
are we talking about the transplant kit?
you don't need to drill and tap anything on the iron block if you have the iron block bracket-there is the bracket, then a square piece that goes from the bracket to the side of the block, and a spacer
I think I ended up using a caddy CTSV pump, because the pulley hit the pressure fitting
let me look and see if I still have any pictures of it-if not, I have to go over to the guys house that now has my car, I could snap a couple pics
LS1Tech Sponsor
I don't have any pic's but below is a list of the items that make up the 3LSPS-003. Bob
3LSPS-003 / LSX PS RELOC BAG IRON BLOCK
AB038A-027 LSX POWER STEERING BRKT IRON BLOCK 1.00 EACH
AB038A-030 LSX PS BRKT BRACE IRON BLOCK 1.00 EACH
BO08MI-025 8MM-1.25 X 25MM BOLT 1.00 EACH
BO08MI-080 8MM-1.25 X 80MM BOLT 2.00 EACH
BO10MI-025 10MM-1.5 X 25MM HEX BOLT 1.00 EACH
CS08MI-100SS 8MM-1.25 X 100 MM SS SHCS 1.00 EACH
CS10MI-100SS 10MM-1.5 X 100 MM SS SHCS 1.00 EACH
CS10MI-25SS 10MM-1.5 X 25 MM SS SHCS 1.00 EACH
NUM08I-01L 8MM-1.25 NYLON LOCKNUT- ZINC /STEEL 2.00 EACH
SP75.406-2.385 3/4" DIA. X .406 X 2.385"L SPACER 1.00 EACH
SP75.406-2.785 3/4" DIA X .406IDX 2.785"L SPACER 1.00 EACH
WA08MI-12-1SS M8 FLAT WASHER-SS 5.00 EACH
WA10MI-21-1SS M10 FLAT WASHER-SS 1.00 EACH
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Sponsor
Thanks, I appreciate it! Bob
__________________
Any fixes for this I'm running into same issues. I have the Iron block Procharger P/S bracket, for info ive gathered so far it looks that procharger designed it for a 4th gen block. Whats the answer for the 3rd gen block?
LS1Tech Sponsor
Is this the hole you are missing? Bob
__________________
LS1Tech Sponsor
I'd go ahead and install it and see how much deflection you get from it missing that hole. You may need to make a brace to go up to a bolt hole in the water pump. Bob
__________________
