Is this a race cover S480 ?
The following users liked this post:
one fast zo6 (02-08-2020)
Just to throw this out there...
Why do larger surge ports make it a race cover? Why would larger surge ports aid in performance? I was under the impression air wasn't being "sucked in" the surge port area in boost. Thought the scroll itself was larger in the "race covers", no?
OP yes That is a race cover.
the Borg Warner Symbol cast into the cover up there by the outlet... The RC has about a 1/4 inch bigger overall diameter than a standard cover. Different part number cast onto the housing. If the cover is as delivered from Borg Warner it will have an inlet bell in the opening.... but the good shops that know that turbo remove it... The turbo flows more air without it.
No. The 3 inch slip fit outlet and the differences in the inlet are the 2 most minor differences between the covers. What your proposing would more than likely hurt the performance of your turbo. There are differences inside the covers that you cant see that makes the race cover better than the standard one.
